Old 24-02-2008, 12:11 PM   #1
bob 351
MIGHTY MAGPIES 2010
bob 351's Avatar
Location: yarram se vic in the shed listening to pinkfloyd and rubbing panels
Default so where are all the cortina experts
so i bought this need some info can i put a 250 crossflow ansd c4 in it also i noticed it's got 4 wheel nuts can i upgrade to and x series running gear thanks in andvance for any info
http://www.fordforums.com.au/showthread.php?t=11210882
myblog
I LUV ME FLOYD
for sale xc parts pm me for detail
bob 351 is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2008, 12:58 PM   #2
redxm
64 Deluxe 4 door
redxm's Avatar
yep 250 & c4 will fit
if the engine comes out of a falcon you will need to change the sump
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2008, 07:06 PM   #3
fmc351
let it burn
If he wants a dipstick, he needs to remove the tube from the middle, and drill the one at the rear too. You can see where it goes as theres provision for it at the rear and front too IIRC.
You can block the old one with a tight fitting ball bearing and some stag paste, just tap it in with a hammer.
Old 03-03-2008, 02:09 AM   #4
DRIFT_TE
MENTL-6
DRIFT_TE's Avatar
The Falcon rear axles are too long for the Cortina's im looking around for another option now, without weighing it down with a huge 9 inch.
TE CORTINA-
Heavy engine work, balanced, ported, monster cam, 570 holley, aussiespeed manifold / parts, roller rockers, much much more.....
ask for any details. safe to say 180kw @ tyres
Car set up for street / track Drifting. ask for details
DRIFT_TE is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2008, 03:34 AM   #5
fmc351
let it burn
Havnet done it so dont quote me on it, but I read somewhere here that Chrysler Centura diffs fit. They would be Falcon stud like the old Valiants I assume and Borg Warner 8 3/4. As I said, Im not sure of these things though.
Id be looking at shortening a Falcon BW if the Centura idea doesnt suit. Youd need some serious power to blow one in the lighter Cortina and centres are everywhere if you did. Cheap for LSD and no clutch packs, disc rear, plenty of ratios to choose.
Old 03-03-2008, 03:18 PM   #6
bob 351
MIGHTY MAGPIES 2010
bob 351's Avatar
so ok guys just been talkin with a cortina owner and he has told me the a 302 or 351 winsor will bolt straight in is this true also he says that if i do put a six or eight that i will need to change the spring carrier's as well so any info
appreciated
myblog
I LUV ME FLOYD
Old 07-03-2008, 01:22 AM   #7
DRIFT_TE
MENTL-6
DRIFT_TE's Avatar
Are you asking if a 302 or 351 windsor will bolt straight into a TE. um no it wont you will need a conversion kit. available from castlemaine rod shop. or a couple of other places. sometimes available on ebay. i believe the C4 will bolt straight in though.
FMC351:- thanks for that might measure up the centura diff. see how that goes.
TE CORTINA-
Old 07-03-2008, 07:52 PM   #8
bob 351
MIGHTY MAGPIES 2010
bob 351's Avatar
so what would you need if the c4 fit's in ok you would only need some engine mount to suit the corty plates would'nt you
myblog
I LUV ME FLOYD
