Old 17-11-2007, 11:46 PM   #1
JG33Y113
XA&XB&XC
JG33Y113's Avatar
Default 85 Telstar Accelerator Cable URGENT!!
Hi All,
I'm in Morwell, Country Vic and had an Accelerator cable jam up. Any help on where to find one? before Monday...It's a 1985 Telstar
thanks
Greg
JG33Y113 is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2007, 12:59 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
you take off the cable and hang it on the cloths line and feed it with oil or wd 40 inside the outer cover then try to get it moving backwards and forwards
if the strands are broken inside you can try to cut the most annoying ones
do you have a push bike handbrake cable ?
if you have to improvise
depends where the break is
I can only suggest twist/ patch in the right length or
fencing wire or wire coat hanger
if the outer cover is the problem a PVC hose or off a fish tank
or something a similar thickness even tape will do
and if still a problem a return spring at the carby
My car goes Brumm Brumm
