Old 05-06-2007, 12:14 AM   #1
doidz
Default Little help and info needed about escorts plz
Hey everybody need a hand with my RS2000.
Allrite well i bought it not too long ago and obviously coz its such and old car it needed some work. As it is a rare car, parts are hard to get your hands on. One of the things that needs replacing is the whole front right suspension strut. Do i need to "somehow" get a another one, get a different setup altogether for the front or are there some interchangeable parts...like from a cortina?
Help is much appreciated
doidz is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2007, 12:45 AM   #2
atec77
Speak to repco or similar > maybe whiteline and they will order one for you
Old 05-06-2007, 12:00 PM   #3
Aussie_Escort
Aussie_Escort's Avatar
Is it the actual strut bent or something? Repco wont have a strut. They will have srings, shockies etc though.
Aussie_Escort is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2007, 12:23 PM   #4
doidz
Yes it is the actual strut that is bent. The thing is bent down the bottom so the camber of the wheel looks like a V8 supercar setup lol. I knew that repco had all that but like aussie escort said i don't think they will have a strut. Isthere any simple, hopefully cheap alternatives for the time being? or would i have to spend a large sum of money?
thanks
Old 05-06-2007, 09:37 PM   #5
Aussie_Escort
Just try and get a set of 2.0L struts (could be fun though) or capri (even more fun & more $$$). Cortina struts will need some machining done and any other struts that will fit are taking a step backwards eg, 1.6 struts. Try some wreckers!
Old 05-06-2007, 09:51 PM   #6
krt10
eskyman
krt10's Avatar
try classicford.mine.nu they have a for sale section if you need to buy parts
who says kents cant be quick
krt10 is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2007, 01:27 AM   #7
doidz
Thanks aussie escort and krt10 for the help, i appreciate it. Well i guess it does cost $$$$ to maintain a vehicle such as this.
Old 06-06-2007, 02:57 PM   #8
RSgerry
Well hello Mr Fancypants
RSgerry's Avatar
1.6 struts are smaller than the 2 litre struts and i dont think they bolt straight on (someone else can clarify that). dont waste your time with them, get a pair of 2 litre struts. any old carill require time and money to be spent on them. once you get the handling sorted, you wont have more fun in a car.
RSgerry is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 06:54 PM   #9
orangemk1
1.6 struts are the same they shuold bolt in its just that the brakes are bigger on a 2 litre strut also the early mk2s had bigger strut tops the same as a mk1
orangemk1 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2007, 07:45 PM   #10
Aussie_Escort
2lt struts ARE different to the 1.6 but they will bolt in. They however DONT have bigger brakes. The capri struts have bigger brakes but DONT bolt into a mk2. The strut tops are interchangeable so just use which ever you have on the car now with the new struts.
The 2lt struts are are stronger but are more expensive so it depends on how much $$ you want to spend.
