21-05-2006, 08:29 PM | #1 | ||
My car is talking to me, I have a au11 xr8 ute 5 speed manual standard. When I accelerate in first gear and than depress the clutch I hear a beep, then the same into third, sometimes when slowing down and braking. It does it often and every time I drive the car. Just a short beep.
21-05-2006, 08:51 PM | #2 | ||
AULTD
Do any warning lights come on?
Could be the low level sensor on the windscreen washer bottle or the coolant sensor. As you are accelerating or braking the fluid sloshes around and can cause a beep. The light on the dash comes on at the same time though, but only for a sec so you can miss it. |
21-05-2006, 09:03 PM | #3 | |||
Burnin Rubber
Could it be a short on some wiring on the gear box? occurs with 1st and 3rd, suggesting the top gate on the box?
2001 AUII Forte (LPG) K&N Air Filter Tickford Air Intake ***Coming Soon: Clear Side Repeaters*** Quote:
21-05-2006, 09:08 PM | #4 | ||
no warning lights and its doing it with clutch in clutch out, braking etc not at the same rpm or anything you can narrow it down to. driving me crazy! migh check gearbox wiring, thanks.
21-05-2006, 10:05 PM | #5 | |||
FTF Car Club NSW
i find it funny how when the washer bottle is empty the damn thing beeps its head off, more than if you are running out of fuel!!! : |
21-05-2006, 10:52 PM | #6 | |||
21-05-2006, 11:13 PM | #7 | ||
Or you could take an axe to the cluster and disable the speaker
