Old 27-09-2024, 06:20 PM   #211
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Re: Puma Axed except for EV
Originally Posted by DFB FGXR6 View Post
In the case of the last two, who cares if they are slower without forced induction, you would never tire of listening to those naturally aspirated V8's.
I want the fastest one with the most torque that I can make it go faster with software changes on the dyno.
If you want the one that sounds the best, there's plenty of 1990s Holden 304/5L getting around you can have for a couple thousand bucks
Old 27-09-2024, 07:27 PM   #212
Nah, I'll pass........................
PX MK II Ranger
FG XR6
FG X XR8
Mustang GT
Old 27-09-2024, 09:31 PM   #213
asagaai
asagaai's Avatar
Originally Posted by Sprintey View Post
Did you have to do anything more to it to run the E85? Eg replace lines/fuel pumps
As I said I am running a Dreamscience 99+ octane tune.
So I am mixing in 17% e85 in with 98 octane super to boost ocatane.
I am mindful about the problems with lower energy density of E85 and therefore the need to have bigger fuel pump and injectors if going full e85, hence I use a lower mix of e85 with 98 to bump up the octane rating.
And it does make a difference, getting the mix of e85 with 98 compared to 100% 98 I can feel the difference, engine is more crisp and immediate at lower revs, and higher boost and revs just pulls that much harder.
Also the car is built to run ethanol mix fuels, just not 100% e85.
Ford Rides:
Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K
FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender
asagaai is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2024, 09:37 PM   #214
asagaai
asagaai's Avatar
And it does make a difference, getting the mix of e85 with 98 compared to 100% 98 I can feel the difference, engine is more crisp and immediate at lower revs, and higher boot and revs just pulls that much harder.
Ford Rides:
Old 28-09-2024, 09:01 AM   #215
jpd80
jpd80's Avatar
Years ago, Ford and MIT were working on a dual fuel approach to replace diesel,
The turbocharged gasoline engine used two fuel injection systems,
- port fuel injection using 91 ULP (about 95% volume)
- Direct Injection using E85 for detonation suppression (approx 5% of total volume)
By all reports, a test 3.6 V6 was producing 600 hp/600 lb ft on mostly US PON87 fuel
Ford then made the system with just one fuel supply and avoided paying MIT any royalties…
That system also avoids a bunch of problems with gasoline particulate issues that mostly
occur at cold start up but also helps the whole emission profile over straight DI engines.
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2024, 03:02 PM   #216
Sprintey
Sprintey's Avatar
Does the Dragon 1.5 have a dual injection system?
I6 + AWD
Sprintey is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2024, 04:44 PM   #217
asagaai
asagaai's Avatar
Yes, direct injection and port injection. Stops carbon build up which is a problem in direct only engines.
Ford Rides:
Old 28-09-2024, 06:08 PM   #218
Sprintey
Sprintey's Avatar
I found a really good engineer's write up of the 1.5 Dragon if anyone is interested. Tricky cylinder deactivation tech.
https://engineprofessional.com/artic...Q420_52-58.pdf
I6 + AWD
