Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
#2041 | |||
Suggest you try someone like Rocket Industries to see if there is an aftermarket equivalent through a brand like Fel Pro or the alike. Maybe contact Herrod Performance in Melbourne who worked on this things as well. |
#2042 | |||
More information required, GLi, Outback, XR etc? Even a VIN will help. GT |
#2043 | |||
FG 4.0 Air Cleaner Non Turbo.png |
#2044 | |||
It's for an NA FG Mk II xr6. Looking at the image you uploaded its 9B600 |
#2045 | ||
#2046 | ||
#2047 | ||
#2048 | ||
#2049 | |||
'97 XH Falcon Longreach
Hope that helps. |
#2050 | |||
EF9F715A is part number, will check later and get back to you. |
#2051 | ||
No luck on the EF9F715A, keep an eye out on the usual places.
#2052 | ||
#2053 | ||
Regular...with metamusal
![]() Join Date: Oct 2009
Hi Legend
![]() question today is - the 'egg crates' that support the front bumper, when did they change from the plain?. examples below ![]() the black lower pair are what i know/believe were standard on BA/BF, but i have NO idea what the white/black upper pair are off?. any chance you could explain what's the go is?. Thanks ![]() Ps.i believe the upper pair do not fit the later BF2 bumper. |
#2054 | |||
Here are the relavent part numbers: For BA BF XT, Futura, Fairmont, XR, Ghia, XL, XLT, RTV & All FPV BAF217D926A: RHS 7/2002-9/2005 BAF17D926A: RHS 10/2005- 9/2006 BAF217D927A: LHS 7/2002-9/2005 BAF17D927A: LHS 10/2005-9/2006 BAF217D926A: RHS 10/2006 on BAF217D927A: LHS 10/2006 on LWB Fairlane/LTD take the below for all: BAF217D926A: RHS BAF217D927A: LHS Hope that answers your question. |
#2055 | |||
Thanks Legend, with that 09/2006 timeline is that roughly when they changed the front springs from the earlier BA shape?. best see IF i canna find some part numbers on em 'crates' ...... cheers |
#2056 | ||
The white I have is on the AU2, both front and rear.
#2057 | ||
#2059 | ||
Front spring change in BA seemed to happen around 7 or 8/2007 pending on model.
#2060 | ||
“Long shot” again.
The bulb holders for B-series cornering lights. Were they serviced individually as spare parts, or was a compatible bulb holder used elsewhere on same era Fords? |
#2061 | |||
#2063 | ||
#2064 | ||
#2065 | ||
Just the holders, if you can please. The lamp bodies I have are reasonable, they look nicer than the blanking pieces so I might as well make them work.
#2066 | ||
I have these holders from cornering lamps and a set of good second hand lamps with holders too..
But for the life of me I cannot work out how to load a good picture on here, parts images seem ok as they are less than the size limit, but a picture goes over and don't load like the others do? |
#2067 | ||
I trust your knowledge of the holders being the right part - no picture required. If you tell me “kemm” I can leave an envelope under the doormat for tomorrow.
#2068 | ||
Would rather send you a pic as the holder has wiring connectors adjoining it. Send me a PM with an email and ill send a pic..
#2069 | ||
is there enough holders to go around?.
#2070 | ||
I only have 2 holders, but they have wiring plug attached and then a set of lamps including holders as per image that Citroen posted below.
They extra holders with wiring were in the same box and the lamps but my memory is vague as to what they are off. Best to view somoehow. If someone can advise how to post images, I would try. |
