Old 11-07-2024, 07:47 PM   #1
Fatbob103
Default Converting Air Con to Hychill.
Howdy
Replacing the aircon compressor on my patrol so will need to have it regassed.
Thinking of doing the change over to hychill so I can do it myself as I can get the gas and charge hose for $130.
Anyone done it before and have any tips?
Fatbob103 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2024, 07:58 PM   #2
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
Default Re: Converting Air Con to Hychill.
Yes, have done it.
One thing to consider is the suction hose. Hychill have an article on reduced barier suction hose leakage. Hychill recommend replacing these hoses. Also do the o rings too.
Perhaps as a 1 off it won't be cheaper. You need a vacuum pump, manifold set, scales etc. Purchasing them will come to more than getting a regas.
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 11-07-2024, 10:37 PM   #3
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Originally Posted by Fatbob103 View Post
Howdy
Have done it on my own cars and a couple customers, can recommend, cools better than R134a,
First car I did was my LV Focus, that thing was terrible typical Euro junk, above 30 degrees ambient temps you'd be lucky to get 17 out the vents.
Gassed it up with Hychill and 1.6 degrees out the vents:
30% charge by weight compared to R134a, probably not a concern on a Patrol but it wont work on shitful Euros using pressures to control the AC output as it operates at significantly lower pressures than R134a.
Don't bother buying the gear, just find a local workshop who does hychill I got a set of charge scales on sale recently and those alone were $220.
Did it in my EF as well, 0.7C out the center vents.
Old 11-07-2024, 11:09 PM   #4
Fatbob103
You interested in a ca$hy Franco?
Old 11-07-2024, 11:10 PM   #5
Franco Cozzo
Thailand Specials
I don't have a vac pump unfortunately, I've got the gauges and the scales, the vac pump is the next piece of the puzzle, I'm slowly piecing together all the kit to do it again
You need to pull the system into a vacuum for a while, then let it sit to see if it maintains it before you charge it.
You'll be able to get it done for around $200-$250 I reckon, its just a challenge finding a workshop that will use it because there's was a huge scare campaign on behalf of DuPont who has the licencing for R134a to scare people off using alternatives (that work way better and aren't under some ridiculous licencing system courtesy of the retards at ARC).
TaT which is a local automotive aftermarket group also carried on about flammable refrigerants, but both TaT and DuPont seem to be rather quiet about their flammable replacement for R134a - R1234yf.
If you contact HyChill they'll be able to put you onto someone they know who uses it, they used to be fairly active on the internet trying to dispell propaganda spread about their product.
