03-05-2024, 12:11 PM | #1 | ||
What is the normal procedure if you suspect you have filled up a tank with bad fuel?
Last weekend we filled up mum's Kia Sorento (Diesel) at the local BP. Car started fine after filling. Drove half way to Geelong and stopped over for a coffee. Got back in the car, went to start it, and it just kept cranking but not firing up. I turned the car off, and tried again, again extended cranking, then finally started. Car drove fine but sounded a bit noisey at low RPMs in 1st and 2nd gear. The car has been like this since. I told the folks to go to a reputable mechanic shop and get them to submit a fuel analysis. For some reason, dad didn't want to do that. Instead he called his mechanic mate who came over and ran some diagnostics via the ODB2 port. Not sure what software was used, but it cleared up the car a little and started ok that evening. Next morning, extended cranking again. I told dad to go get some fuel pumped up and tested by a shop, again he ignored me, and instead bought a bottle of Fuel Dr and put it in. Its been 2 days since Fuel Dr, its running slightly better, less extended cranking but still not normal. And on morning start ups, it emits a lot of smoke for the first couple of minutes. He is now asking me to call BP........I'm banging my head against a brick wall as I doubt they will accept a fuel test now.
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
03-05-2024, 12:18 PM | #2 | ||
It sounds very much like a car problem to me. Do you use algaecide regularly?
Check the Google Reviews for where you last bought a sizeable amount of fuel. Negligible bleats will confirm where you should direct your efforts. |
03-05-2024, 01:17 PM | #3 | |||
Car has been running flawlessly since new, never missed a beat, no gradual symptoms , then all of a sudden this happens.
03-05-2024, 02:00 PM | #4 | |||
Cabover nut
No fuel tanker on the forecourt when they were filling ??
03-05-2024, 02:10 PM | #5 | ||
Nup....
03-05-2024, 08:21 PM | #6 | ||
I filled up a diesel with 98 in error once
Diesel hose- green 98 hose- green Vehicle symptoms sound like yours |
03-05-2024, 08:48 PM | #7 | ||
Experienced Member
As you stated without a fuel analysis you just guessing, you have no grounds with BP for compensation unless you can prove it is dodgy fuel. you could be lucky if others have put in a claim for the same problem on the same day, get him to get the fuel tested or a mechanic to certify they checked the vehicle after refueling.
03-05-2024, 09:30 PM | #8 | ||
Is it like food poisoning claims? A single claim won't go anywhere usually but with more people at the same place at the same time a pattern makes thing more objective. The internet makes this much easier than before.
03-05-2024, 10:05 PM | #9 | ||
onything on FB popping up about the servo
04-05-2024, 04:19 PM | #10 | ||
On second tank with fuel Dr. I haven't driven it but heard my dad take it out today and it sounded normal. He said it was acting normal.
I would not entirely discount that he may have put the wrong fuel.... I dont know much about diesels, but once it started it was running fine? No power loss. Just a bit noisy at very low rpms in gear. Wouldn't wrong fuel make it run like crap? Google reviews showing nothing. The BP fb page is only posted by bp, no public posts. Though if everyone reacted the same as the old man, then it wouldnt show up on social media Just out of interest, how much does a fuel analysis cost?
04-05-2024, 04:22 PM | #11 | ||
04-05-2024, 07:31 PM | #12 | |||
I was certain I saw dad lift the diesel tab to pull the hose out that morning, and he reckons he 100% did lift the tab. So I suspect maybe someone put the premium 95 hose on the diesel housing. I'm surprised the pump and injectors haven't collapsed given we've used 3/4 tank. The car is now back running normal. From what I've read, it should have died by now.
04-05-2024, 07:53 PM | #13 | ||
It takes a while.
In all seriousness, I would get the car beautifully detailed up Monday and sell it that same week. |
7 users like this post: |
04-05-2024, 07:58 PM | #14 | ||
04-05-2024, 08:17 PM | #15 | |||
Funnily enough, he got a dealer quote 2 weeks ago as he is looking to trade it in for something new You just know when the universe is telling you something!!
04-05-2024, 08:20 PM | #16 | ||
Rob
https://www.wrongfuelrescue.com.au/p...-a-diesel-car/
There is a small percentage of cases where it doesn't end badly however the large majority will end up requiring expensive repairs especially if continuing to run the wrong fuel through the system.
UA2 TREND 4WD BI TURBO |
04-05-2024, 08:47 PM | #17 | |||
Get a 32A single phase circuit installed in the garage for fast charging on single phase and move them over to one of those energy providers offering 8c/kWh off peak rates for customers with EVs and charge between 12-6AM. Few and far between maintenance, no servos to put the wrong fuel in anymore and $2/100km running costs. |
04-05-2024, 08:52 PM | #18 | |||
If its stuffed, its stuffed, nothing he can do now. But its sounding healthy again so fingers crossed. I'm taking it for a run tomorrow so will get a feel if something still isn't right.
04-05-2024, 08:54 PM | #19 | |||
I'd still be getting rid of the thing, its on borrowed time and that borrowed time is sooner rather than later. |
3 users like this post: |
04-05-2024, 08:58 PM | #20 | |||
04-05-2024, 08:59 PM | #21 | ||
New plan - keep the Kia until it lets go and make him pay to fix it so he can't afford the Haval
4 users like this post: |
04-05-2024, 10:32 PM | #22 | ||
The Vw Transporter diesel I filled with 98 was a transport fleet vehicle. The coy workshop couldn’t figure it flicked it a vw dealer who had it for 3 weeks changed a few bits and that van ran for another 100000kms. Initially the coy workshop drained the fuel tank so I guess that helped.
Due to a weekend and coy workshop and vw dealer getting themselves mixed up I never got my **** kicked. |
05-05-2024, 08:20 AM | #23 | ||
Cabover nut
Is he going to remove the GWM badges like every ute buyer seems to be doing ?
