Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
#721 | ||
Hi GTLEGEND, I'm after the falcon outline badge that goes on the drivers side front guard on a FGX XR8?
Someone decided to flog mine this week... Its the chrome badge that goes on the black plastic shroud? http://marks.htmlplanet.com/FGX/fgx_badge_sidexr8.jpg ![]()
Kinetic FGX XR8 ![]() Old Rides: BF MkII 07 XR6 , Seduce in colour.... ![]() AUII TE-FORTE Monsoon Blue,Full Cobra Performance exhaust system, G+D CAI, Crow Cam, Tickford Suspension, TE50 Kit, RDA Slotteds, Ridin on Advanti 18's
#722 | |||
Its not a sprint is it? There are a couple of different options, a VIN would help narrow them down. |
#723 | ||
Mr GT,
I am trying to track down part labelled 14605 on this: ![]() I believe its part number SX 14605 A. It's some sort of rubber grommet that locks the stud on the bottom of the ABS module into the bracket. I've come to find its NLA. But wondering if you had some magic box of tricks where one might be stored. Also wondering about the small length of hose that connects the steel fuel filler pipe to the tank on a BF sedan. Again I understand its NLA, but thought you might be my Santa that comes early this year to surprise me with one you conjured out of thin air. If necessary VIN is 6FPAAAJGSW6L56587. |
#724 | |||
No luck on that grommet unfortunately, might be a wrecker job. The fuel hose I believe was only sold as part of the filler neck, BAF9034A, they are also long gone. |
#725 | ||
Barra Turbo > V8
Just checking in with this one if anything has become available?
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ Tuned by LS Tuning and Performance -2022 Hyundai Tucson Highlander Diesel N Line |
#726 | |||
That hose in Dad's car is perished. Had about 6 splits in it that would weep fuel and fumes. Had Gates brand on it. I think the one in my BF is starting to do the same as well. Typical Ford making it difficult though. One end is 26mm and the other 30mm. Anyways, I had my fingers crossed. But as always, thanks for your efforts. |
#727 | ||
#728 | ||
GTLEGEND,
G'day mate. Hope all is well in your neck of the woods. I have an EL transmission box but would like to know if this is the correct dipstick for the EL. Part Number 90DA-7A020-AA ford Cheers, bondy |
#729 | |||
But yes that is the the correct auto dipstick for a BTR 4 speed auto from EB to EF.. |
#730 | ||
Hey GT,
Any idea on part numbers and prices for either of the following, FG/fgx ZF gear shifter and surround OR FGX Sprint gear shifter and surround. |
#731 | |||
FGX Sprint shifter and surround: Manual: ER2Z7277A around $560 plus (might be able to get cheaper but have to enquire). Auto: ER2Z7C453BAFS around $250 plus (part is restricted so a VIN will be required). |
#732 | ||
Hey GT can I get prices on the following please.
FG F6 MKII auto shifter FG F6 MKII D/S window switch FG MKII Ute D/S window switch Cheers Last edited by hodge_williams; 06-04-2022 at 12:19 PM. |
#733 | ||
#734 | ||
I tried to self-search but obviously not using the correct term.
The bulb holder for the park light in a BA/SX/SY headlight. Need just one - discovered it had been “shonked” with a rogue item and pink slip is due… |
#735 | |||
BA Head Light.PNG |
#736 | ||
FPV 082
Hi Gt,
looking for pricing on wheel nuts to suit 03 ba gt? If they are available Cheers Sent from my SM-G973F using Tapatalk |
#737 | |||
Can you confirm the vehicle has 18" wheels? The front wheel nuts are different to the rear on a BA GT. Can get rears but expensive at $25 each plus freight. The fronts are no longer available. GT |
#738 | |||
FPV 082
It looks to have had locknuts but they are long gone along with a couple of others around the traps. Any chance you have the original lengths? May be easier to try and get something close. Sent from my SM-G973F using Tapatalk |
#739 | ||
Sorry I don't, I only have part numbers..
#740 | ||
FPV 082
All good, thanks anyway I'll keep searching!
#741 | ||
#742 | |||
https://www.ebay.com.au/itm/25428525...frcectupt=true |
#743 | ||
PS in the catalogue that is described as "Position Lamp Socket".Part number BAF13411A.
#744 | ||
Thank you - sounds a very American description!
I expect to know by Sunday night if there’s a used one being made available - if not, will confirm total and transfer. |
#745 | ||
Hey mate after the following please, this is my VIN 6FPAAAJGCMCL90649.
2x FG MK2 ZF 6 speed shifter 2x FG MK2 UTE Window driver side switch 1x center console polished black shifter and cup holder surround |
#746 | |||
Prices above. You will need to add postage also if required. PM if your interested. GT |
#747 | ||
#748 | ||
GTLEGEND.
Would you know if the boot cover that goes onto the rear park brake lever of AU2 is still available? I was looking at it today and its stuffed , requires replacement. If not available, is there an equivalent? Thanks |
#749 | |||
Maybe something like this: https://www.ebay.com.au/itm/23116013...UAAMXQaBtQ-5hJ GT |
#750 | |||
![]() Join Date: Oct 2006
Nah; I think he was actually looking for the small rubber dust covers where the break shoe actuating leaver attached to the hand brake cable goes into the rear drum. The bit shown in figure 5 and 6 in Section 2-6-4 of the AUIII workshop manual. Or Figures 5 and 6 here http://fordforums.com.au/wsmpub/augx/Part%202-6.html See his original query here https://fordforums.com.au/showthread...53#post6698753 Looks like he found them here too: https://www.ebay.com.au/itm/20221100...AAAOSwndZacUuj
regards Blue Last edited by aussiblue; 11-04-2022 at 06:04 AM. |
