Old 22-11-2021, 11:25 PM   #1
auc-05l
Default LS Focus real world fuel economy
Hi all,
I have a LS focus Zetec 2.0 petrol Auto. My economy is consistently around 12.8L/100kms. This seems really high or is it normal for city driving? what are other people getting?
auc-05l is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2021, 06:29 AM   #2
burnz
VFII SS UTE
burnz's Avatar
Default Re: LS Focus real world fuel economy
i would say that's high..
wife's suzuki 1.5ltr gets around 6.8..
my ute 6.2ltr gets 13.3...
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2021, 08:55 AM   #3
brucewarring
My LS Ghia averages 10.9
brucewarring is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2021, 09:19 AM   #4
Peter B - CV8
Seems high - even for city use. What is your average speed ??
My wife's Mazda 6 (2.3 petrol, auto 5 speed) gets 8.9 in city driving (av speed 40 kph)
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2021, 09:38 AM   #5
brucewarring
Just checked....34kmh....10.4lt/100
Old 23-11-2021, 11:40 AM   #6
brucewarring
If thats too high what can i do about it....change the oxy sensors? any suggestions
Old 23-11-2021, 05:32 PM   #7
auc-05l
Seems like everyone is getting significantly better economy..... any idea what can cause this? the car runs fine, has no codes. i have replaced the temp sensor and thermostat, pcv valve and hose, also the throttle body. haven't done the o2 sensors as the live data scan shows sensor 1 voltage fluctuating as normal
open to suggestions.
Old 24-11-2021, 09:47 AM   #8
Peter B - CV8
With that average speed you're going to struggle to improve your petrol consumption + being in North Qld I'm guessing you probably run the air con a fair bit as well..
Old 24-11-2021, 09:49 AM   #9
Peter B - CV8
Pull the spark plugs & inspect/compare or replace if needed.
Old 24-11-2021, 12:26 PM   #10
Rs31markie
I’m up in FNQ so my ac is permanently on. My car averages 8-8.6, if I take it on a run that goes down to below 7. I’d say you have a problem
Rs31markie is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2021, 09:44 AM   #11
auc-05l
is your auto or manual?
Old 27-11-2021, 10:07 AM   #12
Rs31markie
My car is manual. It is actually a LT .
Old 27-11-2021, 10:09 AM   #13
brucewarring
my car is auto
Old 27-11-2021, 12:32 PM   #14
asagaai
asagaai's Avatar
My Fiesta St 1.5 turbo is averaging 6.5 litres per 100 in urban but is a manual.
Aside from checking spark plugs and gaps, do you have any strong fuel smell outside. May be a leak to vacuum seal that can cause fuel consumption
Ford Rides:
Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K
FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender
asagaai is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2021, 12:49 PM   #15
Rs31markie
My wife had a LS auto a few years ago, it was regularly serviced and that did around 10, it could never get near the manual car fuel consumption.
I’d be checking air filter, and perhaps a throttle body clean
Old 27-11-2021, 03:54 PM   #16
prydey
Rob
prydey's Avatar
what is your ave speed? It should tell you if you scroll through the screens on the dash.
If you provide your ave speed that should provide a good indication of the type of driving and give a more accurate comparison.
UA2 TREND 4WD BI TURBO
Old 28-11-2021, 01:15 PM   #17
auc-05l
average speed was 26km/h when it was doing 12.9L/100.....just reset it and now after a few days its doing 16L/100 average speed 18km/h
there is no fuel smell, car runs and drives fine doesn't feel down on power, the plugs are ngk iridium and were changed about 60k kms ago, going by the service receipts when i bought it (they should last at least 100k kms) they look fine. the air filter was changed less than 5k kms ago when i did a service
Old 28-11-2021, 02:23 PM   #18
prydey
Rob
prydey's Avatar
Probably not what you want to hear but I would suggest it could very well be nothing wrong. It does seem on face value a touch high but with such a low average speed it makes more sense.
Do you do a lot of short trips? Modern ecu's will run quite rich when the car is cold, and short trips and slow speeds will contribute to higher than ave fuel consumption.
Old 28-11-2021, 09:12 PM   #19
fiestaz
fiestaz's Avatar
Based off our LT and your average speed, it sounds pretty right. That is a very low average speed. And the autos are not known for great economy.
2016 Mazda 3 SP25 GT
2019 Hyundai i30 Active.
Old 30-11-2021, 09:35 AM   #20
Rs31markie
I would tend to agree with the last two posts, sounds like for kind of usage the cars getting, the consumption you have would be about right. You seem to have done most things.
Old 01-12-2021, 12:12 PM   #21
Fordman
Fordman's Avatar
I don't think it is unreasonable. The economy varies hugely depending on the driving for me.
For example, I drive the car to a train station 10km away each day and it gets 11L per 100.
However, when I left that job and drive 30mins using mostly freeways, its now roughly 8L per 100.
Fordman is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2021, 12:49 AM   #22
DeKa
It’s about right. I had an LV Focus auto for 9 years. Average fuel consumption over that time was 11.5L/100km (by recording litres of fuel and km travelled each fill, over 73,000km of mostly city driving.
It was serviced on schedule and did have new Oxy sensors at one point - they made it feel peppier but didn’t change the fuel consumption.
DeKa is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2022, 02:50 PM   #23
prumpfy
The only comment I would make is that the thermostat is critical. In my posts on the LS focus in this forum, I found the thermostat was opening at about 40 degrees C. I replaced the whole assembly with a new part.
The new thermo opened at about 85 deg C. This fixed the problem, but short runs in a cold climate destroys any sensible Fuel consumption figures.
Recently, I have become worried that the thermo is opening at lower temperatures, AGAIN! It is taking about 10Km of driving to reach its stable operating temperature. Should be about 5 to 6 Km.
I will check it again; it is a pain to get to the thermo. If it is faulty, I will replace only the thermostat; not the whole assembly.
The car is due to go for service soon. I will get the air inlet hose checked as well. The car over-revs at startup and this is often caused by a split air inlet hose.
See my posts on this subject.
prumpfy is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2022, 07:11 PM   #24
auc-05l
Thanks all for the comments. Aside from the poor economy the car was awesome, but is now sold. Replaced with a diesel vw golf which does 7L/100kms doing the same trip (boot is no where near as big tho). Cheers
