can anyone tell me if headlights from a 2000 series 2,Cougar are compatible with my 2001 car ? currently has one original and one Eibach light.
obviously no one knows if it would fit.
So here is an easy question, the original headlight gets water in it. where do I get it repaired or buy a new seal ? |
So there are two different headlights on Cougar.
From 1/6/1999-31/8/2000 RH F8RZ13008HA LH F8RZ13008JA From 1/9/2000-2001 RH 1S8Z13008DA LH 1S8Z13008DB Hope that helps if you need to find what month and year the donor light will come from to see if its right for your car, ie it needs to be after 1/9/2000 to fit your 2001. |
#4 | |||
Cougar King
Yes both of the Cougar model headlights are interchangeable. I've personally installed 2001 headlights into my 2000 Eibach, which I think look great! See link here: Here!
00 Eibach Cougar Mods: Escape 3.0 V6 ST220 UIM and LIM NPG Fuel Adapter California Clutch Stage 2 Disk and PP ST200 Flywheel Torsen LSD Updated Shift Forks ToyoSport Exhaust Headers Custom 2.5" Exhaust dual BAT 21mm RSB PRT Heavy Duty rear drop links Energy Suspension Polybushes all around Eibach Suspension Eibach body kit 01 Gauges 01 Steering Wheel Aluminium Sports Pedals Sony Double Din HU ST200 Airbox ST200 TB Direnza ST200 Aluminium Radiator Goodridge Brake Hoses |
Wild Racer, the Eibach headlight I had is black so doesn't match the other. Also they don't just fit so we had to take out the little plastic grill and move it out a bit, and make a temporary bracket so the bonnet would close.
I did not want to cut my baby just to temporary fit a headlight, as in your link. and I hope to find the right one soon. But thank you for your help. |
