12-09-2021, 04:39 PM | #1 | ||
Hi, I have posted for a few weeks now some questions I have about an XE, I have had a lot of views but no replies. Where is the best Forum to get technical advice? This is my original post.
Hi all, New to the forum and have some questions I need help with. I have a 1984 XE sedan, 4.1 auto and I am converting to a V8. I have been told that once conversion done a RWC and a view by Vic Roads should suffice. Now my questions, I have purchased a 1984 LTD, 351 complete, I have done this as I believe that a lot of the 6 cylinder components will be no good for a V8, I am replacing radiator, water pump hoses etc with new. I know I will have to extend the tail shaft as the LTD is a longer car. Would the LTD have an LSD? I know it is not a 9inch. The LTD has leaf springs and the XE has coil on the rear, the XE has drums on the rear, What is the best way to get the LTD diff and discs on to the XE? Should I run with leaf or coil on the rear or is it too hard to swap ? Any other ideas or items I should be aware of please let me know Regards Sacko7 sacko7 is online now Report Post |
12-09-2021, 07:36 PM | #2 | ||||||
but me id keep the ltd and flip the xe Quote:
unless they are the same make diff then change the centers fit the disc's to the outers after removing the complete drum set up and fit the vac booster and master from the ltd but like above but me id keep the ltd and flip the xe as you already have it all in that package changing the car from coils to leafs or diff from leaf to coil will more than likely require an engineers cert which will more than likely need some one who can proceed with the job that knows what their doing and the engineer which can become costly
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
3 users like this post: |
12-09-2021, 10:02 PM | #3 | ||
Advice can also be had on Whirlpool, Reddit and Mumsnet, although quality and accuracy will vary!
It may be possible to put the LTD diff internals completely into the XE diff housing - provided the flanges are identical. The whole job should be done thoroughly, a half-baked conversion as these cars otherwise climb in value, will detract from asset growth. Is the LTD shell much rusty? Looking out for a sound front cut, from front floor to shock towers. |
12-09-2021, 10:10 PM | #4 | ||
Yes the inspection should be all as it could've been optioned with a V8.
Dunno about LSD, but pretty sure it will have highway gears in it (lower numerically) not what you want. An E series rear end (eb xr6) will give you a 3.45 ratio and LSD, with coil springs and discs. Fairly common swap, Google will help you here. |
12-09-2021, 10:12 PM | #5 | |||
Thailand Specials
5 users like this post: |
12-09-2021, 10:32 PM | #6 | ||
That's All it's Worth,,,,
Having said That.. My(also Free) Advice is to Leave them Both Original.. unmolested Australian Built Cars have appreciated substantially over the last couple of Years & (IMHO) will continue to do so.. However at the end of the Day. It's Your Car, your Money, Do whatever floats your Boat.. Last edited by hayseed; 12-09-2021 at 10:37 PM. Reason: added a bit. |
2 users like this post: |
12-09-2021, 11:01 PM | #7 | ||||
IT Drone from Sector 7G
From the Vicroads website:
...specifically No. 8: Quote:
12-09-2021, 11:17 PM | #8 | ||
praek tih kl jo kr
Wrecked heaps of these cars back in the day when they were worth nothing
I would start with checking the ID tags of both cars and posting up the engine trans and diff codes, from this we can work out if your LTD has a 351 engine or a 302, FMX gearbox or a C4, A LSD or a single spinner. With this information we can work out if you need to change the diff centre or just the brakes, if you need to get a tailshaft made or just change the yolk, it is a job for someone with a bit of mechanical experience, but not impossible for a first timer with a bit of help from people who have done it before. |
13-09-2021, 05:25 AM | #9 | ||
Thankyou people for your replies and comments and I have taken all advice on board. Unfortunately there is not a panel or sill on the LTD that is not rusted out. I know most things are fixable but this lived out in a paddock for years and the interior is the same. Only the running gear appears salvageable. The Xe has been restored and repainted twice in its life and is fully registered at the moment. On your advice I will contact Vic Roads for their advice. Many thanks again
Sacko7 |
