01-12-2020, 11:03 AM | #1 | ||
I love my diesel Mondeo wagon. But both rear shock absorbers need replacing. Ford want $1200 (each)!!!
Given the low volume here, there is no aftermarket supplier. Repco etc don't have them. But aftermarket shocks are readily available in the UK for around UK 35 pounds or A$65 each. So I'm planning to buy in UK and have shipped over for fitting. Has anyone else done this? |
01-12-2020, 12:35 PM | #2 | ||
These don't fit ? https://parts.monroe.com.au/v/ford-a...hock-absorbers
regards Blue |
01-12-2020, 01:17 PM | #3 | ||
Thanks, but Mondeo is not in the Australian catalogue. Annoying, huh?
01-12-2020, 01:40 PM | #4 | |||
regards Blue |
01-12-2020, 02:20 PM | #5 | |||
Former BTIKD
01-12-2020, 10:35 PM | #6 | |||
Not so much. Those, I think, are front struts. The OP is looking for rear shocks? Perhaps this? https://parts.monroe.com.au/v/p/pass...roductnr=e2071 Good luck Cheers
AlanD Our Drive: Mondeo MD TDCi Titanium Wagon Ruby Red |
01-12-2020, 10:40 PM | #7 | ||
2015 Mondeo could be an MD, though, which arrived here around August that year.
Current car: 2016 Ford MD Mondeo Titanium EcoBoost (2016-) Previous cars: 2005 Ford BF Fairmont (2006-2019) 1989 Ford EA Falcon GL (2000-2007) 1982 Ford KA Laser Ghia (1999-2000) |
01-12-2020, 10:41 PM | #8 | |||
Former BTIKD
01-12-2020, 11:07 PM | #9 | ||
Rear Shock Absorber Part Number E2071 2007-2015 Ford Mondeo TDCi these: https://www.ebay.com.au/itm/Monroe-C...frcectupt=true
regards Blue Last edited by aussiblue; 01-12-2020 at 11:16 PM. |
02-12-2020, 08:32 AM | #10 | |||
https://fordforums.com.au/showthread.php?t=11453047 FrancisW also did for his 2011 MC wagon, but ended up with products that didn't fit: https://fordforums.com.au/showthread.php?t=11478504 As they say, your mileage may vary. |
02-12-2020, 12:27 PM | #11 | |||
But it might be that the car is an MC model as a 2015 year has a couple of possibilities since both MC and MD models were sold in 2015 in Australia. And the MD was a complete redesign so there are a host of differences that could extend to suspension design and mounting details for Dampers. If it is an MD wagon then the fact that the Titanium spec cars have self levelling rear suspension and the lower spec cars do not (I think), this might make for differences in both Damper type and how they are mounted. I'd advise the OP to get under the car (or take a wheel off) and then you can check both the type of Damper (cylinder or strut, I doubt strut) and the mount system (eyelet or threaded rod) - it is then easy to eliminate catalogue entries that do not match. I just looked under the back of our car, which has the self leveling suspension, so I can tell you that on the MD Titanium wagon there is an eyelet at the bottom of the Damper and a threaded rod at the top, but there is at least one tab welded to the lower tubular part that is used to locate other suspension members. The E2071 is not going to be suitable on this car. If the OP goes here: https://www.autodoc.co.uk/car-parts/...07762-2-0-tdci The entry might be helpful - the catalogue is quite extensive. Finally - $1200 for a tubular Damper? - another example of dealership ripping off car owners? Cheers
27-06-2021, 06:10 PM | #12 | ||
Hi Greenspeed. I have exactly the same issue with my 2016 MD Mondeo. My mechanic couldn't believe the price Ford are asking for the parts. He asked for trade price and he was quoted exactly the same as me $2400 for the pair. In his opinion, they're not worth it. Mine failed after only 55k kms. I'm looking at the UK too. Did you end up doing this? Which ones did you order? How did it turn out? Any help/advice would be very much appreciated. Cheers
27-06-2021, 08:08 PM | #13 | ||
Hi.
No, I haven't done it yet. Apparently they are special self levelling shocks. Which is why the aftermarket parts don't suit. My mechanic says there is a modification which can be done to allow standard shocks to be used. But that needs special springs to be made. And its not worthwhile. So, I haven't gone any further with it.. |
28-06-2021, 11:15 PM | #14 | ||
Thanks for the reply. Im still hopeful the uk parts of the will work out. I've found posts on other sites where its been done on the MC mondeo. So fingers crossed 🤞
06-07-2021, 11:29 AM | #15 | ||
[QUOTE=AlanD;6519547]
If it is an MD wagon then the fact that the Titanium spec cars have self levelling rear suspension and the lower spec cars do not (I think), this might make for differences in both Damper type and how they are mounted. I hope you don't mind me clarifying, Alan, but its the Ambiente wagon (only) that has self-levelling rear suspension, utilising dampers of a very large diameter. The Titanium (hatch & wagon) has what the brochure calls "Adaptive Suspension" but the handbook calls "Driver Select Suspension", with Comfort, Normal & Sport modes. A former Ford service manager told me that the Ambiente's dampers are of a fairly simple design & don't usually give trouble. |
06-07-2021, 04:30 PM | #16 | ||
If it does not work and you need genuine shocks (need VIN to verify), but I can get these for $900 each ($600 saving in total). Still expensive I know, but if you have no choice, happy to help getting them.
06-07-2021, 05:22 PM | #17 | ||
Hi - not sure if this was covered in an earlier thread, but a failure at 55,000km is deemed an unacceptable product performance and reliability - you will be surprised that you, the Consumer has right under consumer guarantees and warranty to have Ford replace these at no charge to you!
Be prepared through to do the leg work as the Ford Service Manager is trained well to resist all cost wherever possible that is warranty is dealer have a hard time recovering this via Ford and anything they can charge out is easy money, but you will find with some patience and constant calls to their Customer hotline you will have these replaced at no cost to you! Ford are still doing repairs to cars for warranty works free of charge for cars up to 7 years, and no one will ever publish this officially! Make sure all service records are in order and quote them the ACL (read it cover to cover). Hope it helps! |
08-07-2021, 10:36 AM | #18 | ||
Thanks for all the input.
Mourati - I did think of the ACL. I have a contact at City Ford, Alexandria. He had his service people look at it and try to get Ford to change them under warranty. Ford refused so they refused. I also tried making a complaint through NSW Fair Trading. The reply from Ford was that they would not repair out of warranty, but even if it was within warranty, the shocks were considered a fair wear and tear item so they wouldn't do it anyway! I thought after that I'd have to go through the Tribunal to get anywhere and I don't have the time or money to take on Ford's lawyers. I have no doubt Ford would rather spend more on legal costs, than the replacement cost of the part, just so they dont set a precedent for having to replace these parts. Do you have any further hints or tips how to go about this? I would love to see Ford cough up for them! Thanks Gtlegend - thanks for the offer. I'll keep it in mind. I'm still hopeful of a more reasonably priced alternative, although I haven't ordered the UK parts yet. In the meantime the VIN is WF0FXXWPCFGL45716. Thanks Shepherd - I have the ambiente, and yes, it's self leveling, not adaptive or driver select. You're right about the size of these things, the mechanic mentioned they were huge! The service manager you spoke to is probably right to a certain extent, but if it is rare, why won't Ford just admit the occasional dud and just pay up? (I realise you can't answer that, just venting) It doesn't seem like a huge issue with them, but I've found several examples of the same problem browsing various forums, including Greenspeed3's. |
15-07-2021, 08:23 PM | #19 | ||
I have been researching this myself, as i have a 2016 Ambiente Wagon with a leaking shock.
The only option that i can find is to purchase lowered springs and new standard struts and shocks. I have some links below. http://www.eibachdirect.com/p/935362...mondeo-v-.html https://www.extramileautoparts.com.a...0l-2014-2019-8 https://www.extramileautoparts.com.a...eo-ambiente-20 https://automotivesuperstore.com.au/koni-8250-1043 https://automotivesuperstore.com.au/koni-8750-1113r https://www.ebay.com.au/itm/28435584...8AAOSwTMxf9F1q Regards |
15-07-2021, 08:35 PM | #20 | ||
Has anyone actually thought of the compromise fitting of the cheaper shocks may have on the ride quality, effects on ABS, ESC, DSC, AEB and other safety systems the OE shocks would have been designed to deal with. The MD Mondeo was far superior and more advanced vehicle than say a Falcon of the same era (while it lasted) in most aspects. It would be interesting to know if the cheaper aftermarket shocks actually stand up in comparison to the OE, I doubt it because the difference is usually genuine.
16-07-2021, 03:24 PM | #21 | |||
16-07-2021, 03:50 PM | #22 | |||
Challenge Accepted!
you make it sound like cheaper shocks are inferior. Aftermarket that are suitable for the intended purpose are often OE equivalent and sometimes better. I had poor underperforming suspension, replacing them with known quality aftermarket shocks&springs KYB/Monroe alternatives, restored a beautiful suspension. Best move I've done and 5yrs+ of complete enjoyment. Aftermarket also cater to performance crowds. I wouldn't want to ever be held over a barrel for OE, that just serves Ford.
16-07-2021, 04:41 PM | #23 | |||
If there is a cheaper option that has no issues and does the job equivalent or even better, then go for it. Win Win.. My post was more about being aware of what potential issues could be affected by fitting under performing shocks (maybe I should have used that instead of cheaper). |
16-07-2021, 05:31 PM | #24 | ||
Hi all, my 2015 trend wagon seems to have "normal shocks "not electric anyway bottom mount is far from looking a normal mount. were the electric stabilisers an optional extra, none of the usual suppliers seem to have anything. Cheers NPS
16-07-2021, 06:10 PM | #25 | ||
16-07-2021, 10:18 PM | #26 | |||
Challenge Accepted!
Ah thanks for the clarification, I haven't felt the OP is going in blind, he's still researching. I assumed that he is trying to look for suitable OE replacements. I, too, agree you should shoot for OE where possible first or if you're wanting more, then sure higher performance parts makes sense. I don't thing the vehicle dynamics nor its systems would be affected to the point of abnormal/unacceptable if the OP did away with self levelling for standard shocks with suitable springs. Self levelling is just that, it'll keep the vehicle at a specific ride height fully loaded or unladen. Again reversing that feature, I wouldn't think would ruin the vehicle.
19-07-2021, 12:06 PM | #27 | ||
I have a wagon. I'm not sure if the self leveling was standard here or not. I've found docs showing it was an option in the UK. My car was a Hunter Health Dept fleet car before I had it. Don't think they would have paid for self leveling.
19-07-2021, 03:09 PM | #28 | |||
https://www.ebay.com.au/itm/15444890...MAAOSwQDRgmkjv Look like they came out of a titanium. The seller should be able to tell you if they're right for you. Good luck |
19-07-2021, 04:18 PM | #29 | ||
Thanks David, Yes mine was an ex fleet car so you are probably right they wouldn't spend extra on them. Noel
19-07-2021, 04:27 PM | #30 | ||
Hi David, yes my car was a fleet car as well I think your right they wouldn't spend the extra. Noel
