#301 | |||
WT Fiesta Chrome spot/fog light surrounds are available for $110 each side. I believe the surrounds just clip in. Screws and plugs that hold the actual light in are also available, the screws are $4.70 each (you need 2 per side) and the plugs are $6.30 each (you also need 2 per side of these). GT |
#302 | |||
WT GT
![]() Join Date: Jan 2006
Can I get you to order the screws and plugs for now thanks. |
#303 | |||
Postage will need to be added on top if required. |
#304 | ||
Hi GT,
Can I please have a quote for RH front airbag crash sensor for 2012 Ford Territory SZ petrol 4L? Thanks for your help. If you want me to PM you please let me know |
#305 | |||
The sensor in the doors/pillar are $50 each or the one in the front radiator support panel is $80 plus freight if required. GT |
#306 | ||
Hey GT
Any chance you can buy the clutch master cylinder circlip? Kind of hard to explain but it goes on after the eyelet to keep the eyelet in place. Let me know mate as I have lost mine! Thanks!
2005 BA MkII XR6 Silhouette - SOLD 2007 BF GT Cobra 6 spd manual #43- SOLD 2016 Mustang GT - Current 2010 XR6 Turbo 50th Anniversary - Sold 2006 BF MKII XR6 Turbo Seduce - Sold 2006 BF MKI F6 Typhoon Toxic - Current |
#307 | ||
Hello,
I am needing a sump to suit BF falcon non turbo 6 cylinder Barra engine. That is for a RTV utility. Are these available, as ours is going to be needing replacing at next service, as the the sump plug thread in the sump is stripping out. Thanks David. We are in Tasmania. |
#308 | ||
#309 | |||
#310 | ||
Bf f6 typhoon (6 speed manual ofcourse)
#311 | ||
Here are all the master cylinder and inside clutch parts. Which are you after?
BA BF Clutch Master Cylinder.JPG |
#312 | ||
And this is the external clutch slave cylinder components. Are you referring to part labelled 7C512?
BA BF 6 Cyl Clutch Slave Cylinder.JPG |
#313 | ||
So I am chasing Part number or if its been superceeded to another part number etc
on the bottom of the Part it 3R23-9A 624-AB it came of a BA G220 V8 Fairlane. I just tried to ring Ford and they had no idea. |
#314 | ||
That is an engineering number that corresponds to service part number BA9A624A, air intake snorkel.
#315 | |||
Doesnt seem to show the part im after but thank you for providing that. Sent from my iPhone using Tapatalk
#316 | ||
#317 | ||
Yeah i did. Neither seem to show the part. Its a retaining clip that holds the eyelet in place which this doesn’t seem to show. Any diagrams of the manual pedal box maybe? Sent from my iPhone using Tapatalk
#318 | |||
BA BF Pedals.JPG |
#319 | ||
Long shot indeed, but BAC coolant hoses for a KF TX3 Turbo. Mazda part numbers BP2613691 and BP2613682?
#320 | |||
I believe it is part 9w543 in that diagram!
#321 | ||
#322 | |||
Thanks GT appreciate the help. Will be in touch. Sent from my iPhone using Tapatalk
#323 | ||
#324 | ||
#325 | ||
Do Ford aus sell the coil pack connectors for the AU V8(3 pin)
Or do they sell the EDIS ones that are on the focus/ka they look like they should fit
2001 AU2 220 XR8 - Build thread |
#326 | ||
Hi GTLegend,
Availability and price for a black drivers side seat shield trim for a FGX G6E turbo Cheers
Current rides 2014 FGX G6E Turbo Tuned by Walter@Oztek performance 504rwkw on e85/420rwkw on 98 with a PCMTec flex fuel tune Previous rides - 2010 FG GT (335 build #152) 437rwkw - 2012 XR6 turbo Ute 345rwkw - 2007 Force 6 (build #91) 330 rwkw - 2010 GTE (build #2) 425rwkw - 2010 50th anniversary turbo ute 365 rwkw |
#327 | ||
Curious is the stone tray from AU same upto BF or even FG?
#328 | |||
3 Pin Wiring Connectors.pdf |
#329 | ||
#330 | ||
