#271 | ||
Abuser of Charvels
Thanks
#272 | |||
#273 | |||
Former BTIKD
![]() Join Date: Mar 2005
#274 | ||
#275 | |||
#276 | ||
#277 | ||
Hi GTLEGEND,
Is it still possible to get B pillar cover passenger side (lower part? - below seat belt and it runs to the bottom) for FGX sedan and two black rubber/plastic pieces that run outside on the roof from front window to the back one - not sure how they are called? Thank you, XUSSR |
#278 | |||
#279 | ||
Hi @GTLEGEND;
As per https://www.fordforums.com.au/showthread.php?p=6569995 I'm trying to identify if GT rear hubs/bearings are different to xr8/xr6t/TurboTerritory rear hubs/bearings. Thanks
Vixen BF Mk II F6 with ZF- #216 Stock PB on street tyres - 13.11 @ 107.3 MPH SY TTG ....Grant me the serenity to accept the fact that I can't pass them all, the courage to pass most, ....and the wisdom to hide the bodies of those who refuse to get the hell out of my way!! |
#280 | |||
The BA1109A is also utilized on all BA to BF rear IRS sedans regardless if its GT/XR/Ghia etc., they are all the same. Bare in mind the bearing is available separate if need be, but if you get the hub it comes with the bearing. Part number BA1215A. There is difference in the knuckles between models though. |
#281 | |||
Thanks GTLEGEND. Knuckle makes sense of course. Time to start stripping the problem side and decide if I get just the bearing or hub and bearing.
Cheers Quote:
#282 | |||
hmmm boost
any update on this ? id like to get a set cheers
EL TURBO GHIA GT3582R WOLF3D TUNED BY JEM |
#283 | ||
#284 | ||
Just wanted to give a big shout out to GT for all his help and assistance in assembling the right parts for interior upgrade I'm doing on my original FG.
Heaps of patience and hard work combined with a great sense of humor, good pricing and speedy delivery. Thanks mate! Much appreciated!! Q. |
#285 | |||
#286 | ||
"WHEEZER" POWERED
Hello, I am after a price on a full set of the outer top of door moulds/weatherstrips in black and both left and right roof gutter moulds (may be called drip rail not sure) please.
These are all to suit FG MK2 XR6. Thanks in advance, awesome thing to do for the forum.
#287 | ||
"WHEEZER" POWERED
I forgot to add all 4 (to replace both front door and rear door on both sides) of the glossy Outer Pillar trims in my previous post.
#288 | |||
LHF Top Door Mould: $190 RHR Top Door Mould: $720, no that is not a miss print. LHR Top Door Mould: $440 RH Roof Rail Drip Mould: $85 LF Roof Rail Drip Mould: $85 RHF B Pillar Trim $105 LHF B Pillar Trim $110 RHR B Pillar trim $60 LHR B Pillar Trim $ 60 Freight to be added on top of item. My concern is the roof rail moulds and the top door moulds and because of their size the freight may outweigh the savings in part price as they would be too big for Aus post. Happy to assist though if required. |
#289 | ||
"WHEEZER" POWERED
Many thanks, the freight side of things is an excellent point mate. It will definitely outweigh the discounts. Completely slipped my mind to consider that!
Cheers!
#290 | |||
HI GTLEGEND, would you be able to throw me a price for 2 of the BA1109A?
Thanks Quote:
#291 | ||
#292 | ||
Is there anything like BA18D557AC or the BF equivalent, still on the shelves?
#293 | |||
https://www.grafixunlimited.com.au/ |
#294 | ||
Any updated Part numbers inregards to
EF to BF 5 Speed Gear Knob AU XR8 BA/BF XR6T |
#295 | |||
EF: EH7213A EL: EL7213A EL GT: GTTVE7K327A AU: ER7K327A6 AU TS/TE 50 Blue: TAU27K327A2 AU TS/TE 50 Red: TAU27K327A4 AU TS/TE 50 Black: TAUTVE7K327A BA XLS/XT, 5 SPEED MANUAL TRANSMISSION (T5) OR RTV/XL/XLS/XT): ER7K327A6 BA 5 SPEED, WARM CHARCOAL, LEATHER WITH ALUMINIUM LOOK (XR, 5 SPEED MANUAL TRANSMISSION (T5)): BA7K327A1 BA 5 SPEED, WARM CHARCOAL, LEATHER WITH ALUMINIUM LOOK (GT/GT-P/PURSUIT/XR, 5 SPEED MANUAL (TR3650)): BA7K327A1 BA 6 SPEED, WARM CHARCOAL, LEATHER WITH ALUMINIUM LOOK (XR, 6 SPEED MANUAL TRANSMISSION): BA27K327A1 BA 6 SPEED, WARM CHARCOAL, LEATHER WITH ALUMINIUM LOOK (F6/GT/GT-P/PURSUIT, 6 SPEED MANUAL TRANSMISSION): BA27K327B1 |
2 users like this post: |
#296 | ||
Possible options for the metal clips that hold on the bottom of the side skirts on an au2 xr8 has optioned body kit. U shape clips.
2001 AU2 220 XR8 - Build thread |
#297 | ||
#298 | |||
Any ba bf fpv ones still available? Sent from my iPhone using Tapatalk
2005 BA MkII XR6 Silhouette - SOLD 2007 BF GT Cobra 6 spd manual #43- SOLD 2016 Mustang GT - Current 2010 XR6 Turbo 50th Anniversary - Sold 2006 BF MKII XR6 Turbo Seduce - Sold 2006 BF MKI F6 Typhoon Toxic - Current |
#300 | ||
WT GT
![]() Join Date: Jan 2006
Hi GT,
Having trouble finding a pair (LH and RH) of fog light surrounds/bezels for 2011 WT Fiesta. It's a Trend which I am upgrading. So I will also need the screws/nuts/bolts that secure the lamps, as I bought some repros from Wuhan that didn't come with any fasteners. Looks like https://www.ebay.com.au/itm/13356768...oAAOSw-g5c8Mc6 I realise that OEM Ford $$ may be a bit prohibitive but if you can see what they come in at that would be great. TIA |
