Old 24-12-2019, 08:32 PM   #1
FordCapri72
Default 1972 ford capri 1600 won’t start, any help much appreciated
Hi guys/girls my ford capri 1600 4 cylinder won’t start, not sure where to connect wires, all the wires are connected and it goes click when I turn the key to start it,I have got interior light, reds, radio and front lights all work but just won’t start, wondering if anyone has got a capri 1600 and if I could have a pic of the wires In the engine bay or if anyone has got a diagram that would be much appreciated,
Thanks 😊
FordCapri72 is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2019, 08:47 PM   #2
MDS69
MDS69's Avatar
Default Re: 1972 ford capri 1600 won’t start, any help much appreciated
Was it running before. Is the battery fully charged.
MDS69 is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2019, 09:58 PM   #3
Capriman
formerly ford3000gt
Capriman's Avatar
I've cropped the wiring diagram for the 1600GT which should be the same as your '72 XL?
You could have a suspect solenoid on the starter motor, but I'm no expert!
Sorry the diagram is so small but that's the largest I can post.
Current ride:
'83 Mk.3 Capri, 2.8i, 5-spd
Capriman is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2019, 01:58 AM   #4
FordCapri72
Hi capriman thanks for that, yeah it’s a 1600 xl
Old 25-12-2019, 02:01 AM   #5
FordCapri72
Hi mds69 yeah it’s got a brand new battery and the motor was running before
Old 25-12-2019, 02:04 AM   #6
Captain Stubing
Looking for clues...
Captain Stubing's Avatar
Does the starter motor work? You'll need a multimeter to test voltages at the solenoid, and the starter motor.
A small amount of power to the solenoid provides a lot of power to the starter, through the solenoid.
2016 Ford Falcon FG/X XR6 Turbo you beaut ute
1985 XR4Ti Sierra - Build Thread
1971 Fairlane 500
and... a collection of Jeep Towpigs
and... two collections of rust and some new plastic bits roughly shaped like an F-Truck
and.... some spare metal bits with holes in them
Captain Stubing is online now   Reply With Quote Multi-Quote with this Post
Old 26-12-2019, 12:15 AM   #7
FordCapri72
hi swanny yeah the starter motor works
Old 26-12-2019, 06:59 AM   #8
GXA
Does it turn over?
How long since it last ran?
Has the distrib been removed/replaced?
Is there spark at the plugs?
Is the timing correct?
Is there fuel at the carb?
Is fuel getting to the cylinders?
How old is the fuel?
Our FORD Stable
2008 FG GT-E - Lightning Strike
2015 SZII Territory TS - Winter White
2007 BFII Falcon ES - Ego
GXA is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2019, 07:10 AM   #9
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
I had a 78 escort. One day a small wire came of at the + battery terminal and the car stopped. Wouldn't start until I reconnected the wire. cant really remember exactly . It was 40 years ago.
BA BF FPV starter button repairs. PM me.
Xtreme Ford Tuning
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
Old 26-12-2019, 07:12 AM   #10
arronm
arronm's Avatar
Check the coil wiring.
Xtreme Ford Tuning
Old 26-12-2019, 09:36 AM   #11
Fed
This is like pulling teeth, anyway onward & upward.
This sort of says that the starter motor is not cranking the engine over.
Does this mean it used to work or it does crank the engine over?
Cranking is different to the engine actually starting.
All my old Escorts had bendix starters and sneaky contacts in the solenoids to by-pass the coil ballast, do you know what your's has?
Anything you don't know how to answer just ask.
Fed is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2019, 04:47 PM   #12
FordCapri72
Hi mate sorry for the late reply mine hasn’t got a solinoid on the starter motor mine seperate, it used to turn the engine
Old 27-04-2020, 07:20 AM   #13
chappy60
If its a manual put in 4th and rock the car the starter could be jammed in the ring gear
had it happen to me a few times
chappy60 is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2020, 07:26 AM   #14
superyob
Get the battery load tested. A click can indicate a sad battery...
superyob is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2020, 08:24 AM   #15
Fed
No soup for you, NEXT!
Old 27-04-2020, 11:42 AM   #16
falconhell74
falconhell74's Avatar
NOTE; 12v is loosely termed as battery voltage - easier to wright multiple times
If it hasn't got a solenoid on the starter then there will be a standalone one
follow the battery pos+ cable till you find were its mounted and give it a tap and see if it starts.
if not-
If you have a multimeter check if you have 12 volts to the small wire on the solenoid when cranking , there should be 4 wires to the solenoid 2 x battery pos + power in and out.
2 x small wire 1 x exciter 12v from key which pulls in the solenoid allowing the battery pos + to "flow" through the solenoid when cranking.
1 X small wire to earth or battery neg - .
Note some standalone solenoids are earthed through the mounting and will only have 1 x small wire = exiter wire 12v from key
if you have 12v to exiter wire then you should get 12v coming out of solenoid to starter motor .
if not then solenoid is U/S and replace .
If you are getting less than 12v to exiter wire then you can fit a relay in line to boost the voltage .
If you are getting no voltage to exiter wire you will need to back trace exiter wire to find out ware you are loosing power.
if you have 12v coming out of solenoid then remove starter and bench test by neg -jumper cable to body of starter and pos + jumper cable to pos + lead pole
Note if the starter is good it will jump when it spins.
You need to watch the sprocket at the end to make sure it throws out and spins as if it only does one its U/S
Hope this helps
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2021, 11:11 AM   #17
esky
For whats its worth I have a 1600 powered Mk 1 esky, for 4 years had trouble starting if left for more than a week or so, tried all the usual ,new battery solenoid new starter motor various advice from those lot more savy than me. Auto electrican tried various fixes then recalled had problems similiar with first corollas, fixed by putting a relay to the starter motor, tried it and problem solved. Starts every time now, a cheap easy try
esky is offline   Reply With Quote Multi-Quote with this Post
