Old 25-12-2020, 07:05 PM   #1
esky
Question electric fuel pump
Requesting some advice re fitting an elect fuel pump to my 1600 engined mk1 esky.Car is used only about once a month ,has a 32/36 twin choke weber is the correct pressure a matter of concern ? What is best brand to fit?
esky is offline   Reply With Quote Multi-Quote with this Post
Old 25-12-2020, 07:28 PM   #2
73 4V XB
Frankenford pilot
73 4V XB's Avatar
Default Re: electric fuel pump
I ran a small Facet fuel pump on a warm 2l Gemini for a few years, never ran out of fuel. Don’t recall the exact model but was only a small one.
Cheers Bretto
73 XB GT
Last of the Big Ports
73 4V XB is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2020, 11:06 AM   #3
Rallye Sport
RS The Faster Fords
Rallye Sport's Avatar
No need for an electric pump the factory unit will easily feed a pair of 45mm Webers.
Instead spend the money on a decent fuel pressure regulator, something like this...
https://www.burtonpower.com/regulato...sefpr007g.html
Webers thrive on correct pressure of about 2-3 psi and one of these will make a big difference in its operation.
If you do decide to go for an electric pump make sure you also use a tachometric relay, these run from the ignition coil and cut power to the pump if there is no spark for example in the event of an major leak or accident.
These are probably the cheapest and easiest way to go about it.
https://www.ebay.com.au/itm/Brand-Ne...4AAOSwADtasHs8
Mk1 GT Cortina Project.
FG XR50 Daily.
Old 26-12-2020, 05:18 PM   #4
TER2BO
REV8380
TER2BO's Avatar
I would run an electric pump and regulator as suggested.
The electric pump when primed will supply fuel to start immediately saving the weak starter motors from trying to turn the engine over to get the fuel to the carby. This will also conserve your battery .
I have done this on 2 of my cars with great results.
For Older Racing Drivers
2006 SY Turbo Territory - Dual Fuel, Debunged, F6 Lower Snorkel,Tune, 20"Rims and Pedders Suspension.
Previous Ford Rides
Tickford AU & SVO EA S/wagons - Dual Fuel
Mk1 & M2 Escorts - modified
1969 Mk2 GT Cortina - very orginal.
1964/5 Mk1 GT Cortinas Group N Racing
1965 Mk1 Lotus Cortina Group N Racing
1964/5 Ford Mustang Group N Racing
TER2BO is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2020, 07:17 PM   #5
11ford11
Might be worth a read.....
https://www.racetep.com/manufacturer...uel-pumps.html
Top End Performance - Weber Specific Electric Fuel Pumps - Weber Carbs - Weber Carbs and TWM / Borla EFi Induction - Performance Brands*
