Old 03-07-2020, 04:28 PM   #1
krawczuk
Default repaired " non servicable " heater hose fitting
this is the " non servicable " part of the heater hose from the mondeo.you can see the edge i sanded down on a 45degree angle , then used a knife the cut thru the rest of the plastic from the outer shell. u can see where there are some ribs to hold the hose, and i just used a clamp to tighten hose.. not bad fix for a few dollars instead of + $100
krawczuk is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2020, 04:53 PM   #2
Default Re: repaired " non servicable " heater hose fitting
Well done. Citroën had the same stupid idea in the late ‘90s for a lot of their low pressure hydraulic hoses and some heater hoses. You could skin the ends and fit new hose to the original fittings.
