Old 04-04-2006, 05:49 PM   #1
Matt89
Default 1.6 to 2ltr conversion???
what is needed and what labour must be done to convert from a 1.6 to a 2litre???thanx heaps
Matt89 is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2006, 05:58 PM   #2
R0BD0G
R0BD0G's Avatar
in what
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2006, 07:25 PM   #3
Matt89
sorry a mk2 escort
Old 05-04-2006, 08:43 PM   #4
R0BD0G
R0BD0G's Avatar
r u meaning like to phisically pull the 1.6 out and put in the 2L
You need a gaerbox to suite......Second oppinion would b advised
Robo
Old 06-04-2006, 07:13 AM   #5
whooligan
whooligan's Avatar
All the gearboxes (ratios etc.) in the Mk 2 Escorts are the same, even the RS2000. The only difference is the speedo gear.
Old 06-04-2006, 04:06 PM   #6
R0BD0G
R0BD0G's Avatar
is that the same with the mk1
Robo
Old 06-04-2006, 04:44 PM   #7
Dean C
Dean C's Avatar
About 14 yrs ago I done a conversion in my first car a 70 something Capri. It had a 1600 and 4 speed man & I replaced it with a RS2000 motor and gearbox that I rebuilt. Was a fairly straight forward project for a 16 yr old. The only things I needed to mod was the tailshaft, fuel lines, relocate the radiator and battery, modify the wiring to the altrenator and starter motor. Was a good conversion and looked very much original and a hell of alot better than the old 1600.
Dean C is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2006, 06:07 PM   #8
frogscort
froggy
u gotta change the radiator mount,, which requires some cutting and welding to make the thing fit , bit of wiring , othere than that bugger all
frogscort is offline   Reply With Quote Multi-Quote with this Post
