01-05-2020, 05:25 PM | #1 | ||
Hi Guys,
I bought my XR6 with 6 wheels, it had 1 spare alloy and the standard run of the mill 16 inch in the boot. I have replaced the tyres on the car including the spare alloy without test fitting it in the boot. Now it fits but the retaining bolt isnt long enough. My question is, obviously the retaining bolt is different (longer) but does anyone know if the cars fitted with a factory spare wheel also had a different boot carpet? Further more does anyone have an AU2 spare wheel retaining bolt (for memory AU2 xr's came with alloy spare standard). Thanks, Brent
2022 RAM Laramie 5.7 V8 Here & awesome! 2023.50 Ranger Wildtrak 3.0 Premium Pack, 20 inch wheels. 2024 Everest Sport 3.0 V6 Touring Pack |
01-05-2020, 09:38 PM | #2 | ||
I am pretty sure the boot carpets were all the same in AU series sedans based on spare wheel size, the only differences were based on colour, year model (some AU1's were different to AU2 & AU3), SWB/LWB and if it had factory LPG. So in essence your carpet should be the same if it has steel or alloy wheel.
What size alloy do you have as this will determine the wheel clamp, there are a few to choose from. Alloy wheel (less 17" wheels) take AU 1382 C clamp. 17" alloy wheels like those on XR8 take NUTVE 1A381 A. At a guess, I think you need the AU 1382 C clamp? Similar to this.. https://www.ebay.com.au/itm/32415230...84.m1555.l2649 |
01-05-2020, 09:55 PM | #3 | ||
I just got a bolt, cut off the head and extended my retaining bolt 2 inches by welding it, worked treat.
The boot carpet is all the same. I cleaned mine and then on a very hot day while still damp i put 3 bricks on the leading edge and it dried flush, worked a treat.
01-05-2020, 10:44 PM | #4 | ||
Have you tried fitting the spare in the well face down?
regards Blue |
01-05-2020, 10:53 PM | #5 | ||
01-05-2020, 11:27 PM | #6 | |||
01-05-2020, 11:46 PM | #7 | |||
Try Mr Ford in Greenacre NSW or Fairford Spares in Padstow NSW or Ford Pro in Smithfield NSW or Macarthur Auto Parts in Smeaton Grange NSW. Tell them you need one specific with the 17" factory spare. https://www.yellowpages.com.au/nsw/g...4-listing.html http://www.fairfordspares.com/ https://www.fordprowreckers.com.au/w...l-handbuilt-v8 http://www.macarthurautoparts.com.au/ |
01-05-2020, 11:47 PM | #8 | ||
Cheers mate. Will give it a go.
01-05-2020, 11:55 PM | #9 | |||
regards Blue |
02-05-2020, 12:00 AM | #10 | |||
