08-12-2019, 08:22 PM | #1 | ||
PX3 WildTrak & RTV
So nephew stuck in outback nt
Only light flsshing is the engine imolisation flsshing Swapping batteries didnt help Any thoughts people..im meant to be meeting him in to drive home next week. Any thoughts ?
[COLOR=Red]I really am Falcon Crazy[/COLOR NextGen Ranger Wildtrak with loads of goodies Sold PX3 Ranger Wildtrak 2.0Ltr UHF, Long Range Tank, Bullbar, Snorkel - 104,000km BA Falcon RTV - Project Ute 265,000km Sold PXII Ranger XLT Cool White. 105,000 Sold PX Ranger XLT in cool white, 151,700km on clock. Sold FGII XR6T Ute LTD Edition in Kinetic. Sold FG XR6 Ute Sold BA Falcon RTV. 251,300km.Was a great mate for last 7 years Sold AUII XLS Ute Sold '85 XF & Crashed 84 XF |
08-12-2019, 08:28 PM | #2 | ||
Has it been interfered with - any attempted thefts, has the ignition lock fallen apart, are you using a genuine key or a clone?
08-12-2019, 08:32 PM | #3 | ||
PX3 WildTrak & RTV
Nah hes been so remote no chnace...changes battery thats about it
08-12-2019, 08:41 PM | #4 | ||
Check all the plugs are seated fully - especially those at the bottom of the column and in the kick panels. Lock the car with bonnet up, disconnect the battery and wait a while. Reconnect, unlock the car and try again.
08-12-2019, 08:43 PM | #5 | ||
check ignition switch as mentioned
check interior light fuse check ignition fuse under bonnet fuse box does it have instrument warning lights (reds)-does it crank at all try poring hot water on ecu wriggle connections at ecu does fuel pump prime when key turned on (possible fault with engine relay and or fuel relay) is it in park does it have a fuel cut switch at top edge of left hand kick panel try to supply more detail - is it cranking and not firing -6 or 8- sedan _ did it over heat. etc |
08-12-2019, 09:10 PM | #6 | ||
PX3 WildTrak & RTV
Thanks guys. I haven’t had BA for years.
It’s. 6 auto. Sweet ride when she goes. He’s on bad internet so sending all feedback. I will be there next week. Hope it’s going by then or long trip home via DARWIN
08-12-2019, 09:23 PM | #7 | ||
PX3 WildTrak & RTV
So no crank. Just the odo comes up and yellow hand symbol on dash. No injector noise. Asked him to do some of above. He’s looking for other key. His dad May have it so I need to get that to him
08-12-2019, 11:02 PM | #8 | ||
Check:
a) He hasn't added a magnet or an electronic device to the key ring? b) He not next to something transmitting a radio signal or electrical field or a magnetic field? c) He doesn't have the other vehicle key fob or a fob from another vehicle somewhere close without realising it (you cannot have two active fobs within the Smartshield antenna field at the same time)? I have seen people put on a coat etc they have not worn for a while and found they had an active "lost" key fob in one of its pockets. Does the light ring around the key barrel go on? Is the remote fob battery good (put a new one in anyway)? Has he check all fuses? Especially BEM fuse. In any event, what were the sequence of events leading up to the no start between when the vehicle last ran and he tried to start it again.
regards Blue Last edited by aussiblue; 08-12-2019 at 11:09 PM. |
08-12-2019, 11:05 PM | #9 | |||
BA/F6 BF/F6 SSV/R TTG
Does the starter relay click?? Does the starter motor solenoid click.
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
09-12-2019, 05:15 AM | #10 | ||
PX3 WildTrak & RTV
Thanks all. Car don’t kick over at all. Told him to give starter motor a hit with hammer.
Car started OkY and he drove it 2km to the pub. Went to get back in and go - dead. He changed the battery recently but that’s it. He only has key. There is no remote fob. And apparently spare key is at my joint somewhere. He has only ‘Coon in town and it’s very much an RF free zone at Larrimah. I’ve asked to listen for fuel pump priming. They left battery off it for 20 mins. He will head back to it first light. Thanks guys - we need to try anything before a $$ tow to Katherine.
09-12-2019, 06:02 AM | #11 | ||
If it started with started “encoragment” I recon that’s your problem
Tap it and off you go until it’s had it’s last tap
Pariahs C.C. What could possibly go wrong I post images with postimg.cc (so I don’t forget) |
17-12-2019, 08:51 AM | #12 | ||
How has this shaped up?
