Old 29-12-2017, 01:51 AM   #1
mccann
Default Escort Mk1 Dash Clusters
Hi All
Hope you can help me identify a couple of very dusty dash clusters I found packed away in the garage, I believe both are from a Mk1 Escort, one I believe is a "GT" cluster, but not so sure on the other cluster with 140mph/8000rpm values? Any help would be really appreciated!
Andrew
mccann is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2017, 02:18 AM   #2
yearby
Default Re: Escort Mk1 Dash Clusters
Maybe twincam ????????????
yearby is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2017, 09:16 AM   #3
OLD BALDY
Yes TwinCam.Both worth a Bob or Two!!!
OLD BALDY is offline   Reply With Quote Multi-Quote with this Post
Old 12-01-2018, 12:43 AM   #4
mccann
Thanks for the info guys, after a bit more research, i found this on the types of dash's found in the Mk1 Escort
http://www.classic-ford.org/cfp/tm.aspx?m=44289
  • The 1300XL, E, GT & RS2000 had the 6 dial dash with 130mph speedo & 7000rpm rev counter
  • The Mexico, Twin Cam & RS1600 had deep dished 6 dial dash with 140mph speedo & 8000rpm rev counters.
  • Up to 1970 the volt, battery, oil & volt guages had those word written above each & after 1970, symbols were used!
  • Some works cars used 9000rpm rev counters that are VERY rare!
  • In 1973 the Mex and RS1600 went to the same 7k rev/130mph instrument style as the RS2000.
Old 11-08-2018, 11:45 PM   #5
Fingers
Ex EF Futura Driver
1300XL in the UK had the 6 dail dash, standard dash in Australia.
Fingers is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2018, 01:01 PM   #6
Vesper Martini
Vesper Martini's Avatar
1st one is a 1300 or 1600 GT dash. I had one myself once.
2nd one looks like its from a Mexico
https://commons.wikimedia.org/wiki/F...051994885).jpg
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2018, 01:05 PM   #7
Vesper Martini
edit 140MPH was only for the RS1600/ twincam see below
http://www.oldskoolford.co.uk/ipb/in...he-difference/
Old 18-09-2018, 07:59 PM   #8
smh00n
State of Confusion
The one with the woodgrain is probably a 1300GT from NZ. Points are the red line at 50 km/h and the km/h speedo. UK cars had miles. Worth a cuppla hundred on a good day, it's not that special.
The black one is a genuine twin cam Escort and is worth a lot of money. Think of a number and double it, you will get someone to buy it.
2016 FGX XR6 cab chassis
1970 Mustang base Sportsroof
smh00n is offline   Reply With Quote Multi-Quote with this Post
