29-09-2006, 02:52 AM | #1 | ||
67 XR Fairmont
Can anyone help me determine what my engine block is please? It is a 302 of somekind I think - maybe 351
The casting number is D2AE-OA Cant seem to find any info on it??? Can anyone help????? KEV |
29-09-2006, 06:03 AM | #2 | ||
I think you might be missing some numbers after the OA.
Does this help: http://www.mustangsandmore.com/ubb/FordTechData.html The first two digits indicate year. The letter is the decade; A = '40s B = '50s C = '60s D = '70s E = '80s F = '90s G = '00s The third digit designates body line; A = Ford full size D = Falcon E = Escort F = Pinto, Maverick, Falcon G = Early Comets, Montego, Cyclone H = Medium/Heavy Duty Truck K = Edsel L = Lincoln Mark VII M = Mercury O = Fairlane R = Capri S = Thunderbird T = Pick-up Truck or Bronco U = Econoline Van V = Lincoln W = Cougar Z = Mustang {there are actually many more} The fourth position signifies Engineering group; A = Chassis B = Body E = Engine If it's a Service Replacement part; Z = Ford Division Y = Lincoln-Mercury X = Original Muscle Parts program M = Ford Motorsport, SVO, FFRP The center number, four or more numbers or letters, is the part number. The A at the end of the number indicates that the part is the first version. If it was revised once, it would be B. If it was revised again, it would be C, and so on. When they run out of letters, it becomes AA, AB, and so on. So if we decode this number, D1ZZ-6675-C, we come up with the following: D1 = 1971 model year. Z = Mustang. Z = Ford Division Service Replacement part. 6675 = the group number for oil pans. C = The third version of this part. Also, have a look at this discussion here: http://www.mustangforums.com/archive...1870101-1.html |
30-09-2006, 02:34 PM | #3 | |||
03-10-2006, 12:10 PM | #4 | ||
67 XR Fairmont
Thanks to the guys who replied .... Have discovered it really is a D2AE-CA - which is a 1972 351 ..... The C, really does look like an "O" where the open end of a C is just a tiny thin line (which of course had grease filling it up to complete the look of an "O"
thanks again. KEV |
03-10-2006, 01:43 PM | #5 | ||
P6 LTD
The casting number is not the whole picture. Have a look at the engine number (stamped above the fuel pump) and then have a read of this site:
http://www.fomoco.com.au/ID.html Paul |
01-03-2015, 11:35 AM | #6 | ||
What's the engine code for a BF 6 cylinder petrol none turbo?............regards Magger
09-06-2018, 04:45 PM | #7 | ||
trying to work out if the XM has a 200ci as asvised when purchased? Has 3 plugs & 3 bolt water pump. Numbers from the block as follows;
ARC1DE 6051A Or MC22789 Anyone able to decipher? Appreciate the feedback. Has seen a lot of posts regarding the 200ci and some doubters |
09-06-2018, 11:38 PM | #8 | |||
* 250ci -7 main: 4 bolt water pump and 5 freeze plugs. * 200ci -7 main: 3 bolt water pump and 5 freeze plugs. * 200ci -4 main: 3 bolt water pump and 3 freeze plugs. * 170ci -4 main: 3 bolt water pump, 3 freeze plugs, and a “T” code (or no code). * 144ci -4 main: 3 bolt water pump, 3 freeze plugs, and an “N” code. |
