Old 18-03-2017, 11:51 AM   #1
sednwol
sednwol's Avatar
Default Engine oil advice
I have an AU Fairmont with the VCT engine that has done 240000 kms and is on LPG. The car is both using and dropping oil. The amount it drops is not great but my mechanic informs me seals are leaking from several places. He has advised me to use a thicker oil and to use a "stop oil leak" additive to minimise the leaking. What type of oil would you advise and does the "stop leak" help at all? Thx.
sednwol is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2017, 08:00 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: Engine oil advice
Ok so what are you using now?
UK
Old 19-03-2017, 01:01 PM   #3
sednwol
sednwol's Avatar
Shell Helix 15/W40
Old 19-03-2017, 03:32 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
I used 15w40 on my LPG AU in warm QLD, from 593k to 745k over 10 years.
It would both use and drop oil. The timing cover seal leaked, but it was only 1 drop per night, every night, for 10 years.
And the only reason it used oil (about 300 or 400ml for about 7000kms from memory?) was because I took the car to redline at some point in every outing. Every day. Every single day. For 10 years.
Old 19-03-2017, 04:00 PM   #5
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
Valvoline Maxlife in the same viscosity (imo because of the vct & kays) could be useful imo, guys on bitog rate it pretty high. Worth checking out, good luck!
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2017, 04:53 PM   #6
Blue Dog
This might be coming from out of left field, but aren't the seals there to keep the oil in & the dirt out?
Perhaps an option could be to replace the seals?
You need to find a mechanic a bit smarter than the one you are using.
The suggestion of increasing engine oil viscosity to minimise leakage is ridiculous.
Blue Dog is offline   Reply With Quote Multi-Quote with this Post
