Old 24-09-2016, 09:34 PM   #1
Aether
Default Capri Firewall Holes
This should be an easy one for the experts. I have been working on my Capri and most of the services have gone through the firewall. I think I only still need to pass through:
  1. Speedo
  2. Main wiring loom
The problem is I have no idea what goes where and there's certainly more than two holes left in the firewall. Can anyone shed some light on what these holes are for?
I want to start wiring up the car but I can't until I am 100% sure where the main loom goes.
Any help much appreciated!
A. ??
B. ??
C. ??
D. Speedo??
E. (Beside steering column) - Main wiring loom?
My Capri Project: http://fordforums.com.au/showthread.php?t=11423076
Aether is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2016, 04:09 PM   #2
1973rs
Default Re: Capri Firewall Holes
a choke cable (some only), B - loom plug, c - an after thought, D, bung for oil pressure and windscreen washer lines, e - speedo cable and bung
1973rs is offline   Reply With Quote Multi-Quote with this Post
Old 26-09-2016, 12:46 PM   #3
Aether
That's such a massive help. Thanks!!!
Old 26-09-2016, 12:47 PM   #4
Aether
Oh and any idea how I work out if my car has a manual or automatic choke??
Old 26-09-2016, 01:22 PM   #5
1973rs
An original v6 will have an automatic choke - uses a 40 mm weber -6so it shouldn't have a hole drilled
Old 15-11-2016, 11:18 AM   #6
4117kev
Hi Aether,
Where did you buy your clutch cable? Just before I order one from Burton's.
4117kev is offline   Reply With Quote Multi-Quote with this Post
