Hey all,
In the progress of seat swapping between models, and for the life of me cannot recall how I got the rear electric seat bolts done up/undone.. I cant even find a "that works" method.. Any suggestions are very welcome, bonus points for pictures. Cheers.
Daily: AU Forte Wagon Project: AU Fairmont - Wants to be turbo The Family Car: 2009 G6E Turbo Future fun: 1968 Ford Galaxie 500 |
So far a torx bit in a 7mm spanner is as close as I have gotten.
Ok update.. seems the seat is stopping earlier than it should. Tested the Fairlane and get almost another foot or room..
Any way to release the motor?
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
Is it the motor or is something blocking it?
UK
It goes from half way back the whole way fine, up and down fine, but it feels like its hitting a stop. There is another few inches of thread left but its making a solid thunk when it stops.
I can't see anything blocking it or jammed. If it is the motor is there a way to bypass/disconnect the motor and run it forward manually.
Ill have a look at mine but I've never checked
UK
All sorted. Trimmed an key down and gave me enough room to losen the bolts.
Issue was a slightly bent rail track causing it to jam. Cheers for you input Uncle_Ken
Great news enjoy the seat
![]() UK
