#31 | ||
Hank,
Have mailed you on your gmail. Ron |
#32 | |||
hankb. |
#33 | ||
BASE on the cluster number means it's a base model cluster ... from memory ... Fairmonts came up with FAIR on them as well.
#34 | ||
Hi everyone,
Well the AU is now back on the road. The problem was exectly as described by hankb. The BEM had lost contact with the PCM and thats why I had no crank. I had to have 2 ign keys reprogramed to the BEM then the BEM needed a "Parameter Reset" [handshake to the PCM] The parameter reset can only be done with a proper scan tool of course. This work was done at the local Ford dealer for total cost of $89. Many thanks to everyone who assisted with this problem. Interesting thought:- New ignition key from Ford $143 plus $40 for cutting. After sales key from same locksmith including cutting $90. Both keys work fine. Ron |
#35 | ||
I just had the battery out of my AU2 for more than 10 days due to doing repairs.
All I did was put the battery back in, connected and cranked it over and it fired. Reset the radio code and its lost its presets. I clean forgot all about the Key Code untill I read this. One thing I have noticed is that it is actualy seems to be more responsive to the acelerator and in Cruise (auto), the shifts are more positive than before. A friend suggested the computer had wiped all the previously 'learnt' driving information. If that's correct, all the better. It always seemed to want to 'Hunt' before then 'surge' off. |
#36 | |||
I would have done the job for you only you live a bit far away. hankb ![]() Last edited by hankb; 25-03-2010 at 05:20 PM. |
#37 | ||
A footnote to all this.
Having had the reset done the car ran a little rough for a few days. Now it has settled down and it is running better than ever. I guess the system has now learnt my driving methods etc. In view of the way it is performing I cant help but wonder if having to have everything reset wasn't a good thing. Ron |
#38 | ||
So i have a 2000 au amd after an engin change had a bit of fun getting it up and running etc after haveing a falty fuel pump...after fixing fuel pume got it all running sweet exept a broken pipe on power steering rack which i proceded to fix .
After fixing that tryed to start up and got the half cranks then click click clic nothing...now dont get a darn thing all things come on exept no crank..is this also the BEM and PCM... help please as car is stuck at home |
#39 | ||
After the ignition key is turned to the on position does the SMARTSHIELD hand in the instrument cluster extinguish?
#40 | |||
Spoke to the master-tech and said it could be a fault with my BEM-Blue? |
#41 | ||
Somebody must know how to bypass these smart shields
I have heard of a bloke that can twitch a few wires to bypass this bullshit immobiliser |
#42 | ||
Raven
I'm having a similar problem..My immobiliser light flashes when you turn the ignition on and it won't start..When i leave it on for an hour it goes out then it will start but once turned off it goes to immobiliser mode again
#43 | ||
Hi guys not sure how old this post is but im having trouble with my 99 ford au any tips would be great. It wont start when i put the key in the car doesn't start all the dash lights come on but when i turn the key all that happens is the exclamation symbol.comes on but the park brake is definitely off and it is in park any clue on whats happening?
