i have a rattle around the speedo cluster on my au xr6 .has anyone else come across this problem.any help in fixing this problem would be appreciated.cheers.
i had one , it was the cable from the cluster it can come loose from the steel panel behind the cluster , its held on with a white pin, other than that i'd be unsure.
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
I had a dash rattle problem in my AUI. If you press your hand firmly over the clock, the rattle goes away. Or its more a vibration made worse over rough chipseal.
Got the same thing in my current AUII ute. The press stud style clips seem to get loose, it would nice to know what is the best solution, as I'm disinclined to use aryldite!
Salvaging myself from the bliss of ignorance, while driving |
