Hi, I have a 2011 MC Titanium, the rear passengers side window is permanently open. I pulled the trim off and had a look, a cable has come loose but it was not immediately obvious where is should go. Any help would be appreciated. Can I do this myself or is it a garage job?
Cheers Michael |
Maybe pulling the rear driver's side door trim off and having a look may give you the answer, it'll be a mirror image and should show you where that cable connects to?
2000 State Blue Mondeo ST24 & 2004 Magnum Grey Mondeo ST220 |
Interested to know what the fault is / was...
Keep us up to date!
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please! |
Challenge Accepted!
my neighbours had done the same to the same window, however his has broken part of the plastic mechanism, I don't know if it's the cable anchor point, cable guide (side part) or housing of the actual unit. He's up for the whole lot nevertheless.
I believe he did something and worked it up by hand in the meantime. If this isn't for you then I'd go see a workshop to do the same or for a fix. |
Hi, Thanks, I have propped it up with a small pice of wood cable tied in position, at least then the car is secure. Ill let you know how I go.
Challenge Accepted!
sorry to hear but good work nevertheless.
Hi, Tragedy has struck.
I thought I'd check out the other rear door window mechanism. As I was feeling the cable, tracking it carefully the window suddenly dropped. I had a good look and think I found the area that the cable attaches to. It's plastic and in this case broken and appears unrepairable. I now have two rear windows that are US. Both are held up with a piece of wood cable tied in place. Looks like a job for the dealer. But on a brighter note, I had to replace the car battery at the same time. The one I got was about 5 cm smaller. I initially thought I was going to have to take it back but the holder has three settings and fitted perfectly. (The car system indicated the batter was low and I didn't want to push my luck. The battery indicator was not glowing green as it should as well) Kind regards Michael |
I have just had this happen to me this afternoon also.
Just driving along, window up (as always) and then a noise of the glass dropping!!! It just failed like that!!! Anyway, I was on the way home and contacted Q Ford at Springwood and they were able to get me in first thing in the morning. So off to Ford I go!
Car is in at Q Ford this morning and they have just contacted me to say that it needs a new window regulator. I guess I have no choice!!!
$580 dollars later!!! All fixed...
I had an EA Fairmont Ghia and the window regulators kept failing. It was always funny pulling up at the toll booth on the M5 and having to open the door after jamming the window up with a bit of wood. Ford finally came out with a fix and then no problems.
What would happen is a small pin that held the gear to the motor would fail. If that is what happened to yours you may be able to drill it out a replace it with a bigger pin instead of replacing it. I would be interested to find out what exactly failed. And yes I know I am showing my age talking about stopping at a toll booth. ![]() |
