Old 28-02-2006, 02:48 AM   #1
Jimmeh
Default AUII Forte interior lighting prob?
Hello
I just bought a 2000 AUII Forte and suspect there is a problem with the interior lighting system. When I lock the car... the lights dont seem to turn off : .
Also when the car is started.. they dont seem to turn off. Is there some sort of extra long timeout thing? I've checked all the doors, boot, windows, bonet.
What should i do?
Regards,
Jimmeh
Jimmeh is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2006, 03:29 AM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
havent got the interior light switch on near the headlights switch have u ??? ..lol
seriouslly , i'de maybe check all the switches around the doors and boot etc etc , pull them out , unplug each switch and then push them in , while pushed in test there continuousy with a multimeter , they should break circuit when pushed in (reverse of normal push switches ), and u should get a continuouty beep from your multimeter when the button is released ( as if the door was open ) ... check all the switches for a faulty switches .... i havent personally looked at the AU door,boot switches as yet but i gather they work on the same principal as older cars ..
Old 28-02-2006, 03:32 AM   #3
XR6-VCT-2000
Fantastic Plastic
oh , also maybe check the cluster too for the 'doors open' lcd display , make sure its not lighting up when the doors are closed , if it is then it might be another problem , im not sure if that display works off the switches that control the interior lights for when u open doors too . ?????
Old 28-02-2006, 03:35 AM   #4
Racecraft
they call me Tibbo
Racecraft's Avatar
the delay on the lights when locking is normal...
should go out when you turn the key unless as XR6 ^^^^^^ said you have the toogle in the on position.. Another thing that strikes me in your post is you refer to the interior light as 'they' ... You sure the map lights aren't on?
I am going off memory though I pulled the bulb out of my interior light ages ago and just use the map lights if I need to.
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2006, 03:47 AM   #5
Jimmeh
thanks for the replys
I dont have a switch for the interior lights. The LCD does not show anything either and also the map reading lights are off.
By interior lights, I mean the main centre light and the key switch light (ignition switch).
Regards,
Jimmeh
Old 28-02-2006, 03:54 AM   #6
XR6-VCT-2000
Fantastic Plastic
Regards,
Jimmeh
they all have a switch to turn on and off the interior lights ! , its the little lever beside the main driving lights switch ! ... all the way down dims the cluster/speedo lights - half way up its full cluster brightenss , click it up all the way and it turns on the interior lights , if its all the ways up that little lever , then click it anti-clockwise 1/4 a turn .
Old 28-02-2006, 03:57 AM   #7
Racecraft
they call me Tibbo
Racecraft's Avatar
the little tab has broken off your switch then.. Pop off the knob for the headlights, (just pry it off with a flatblade screwdriver) under that is a disc shaped bit of plastic that **should** have a tab on it for turning on and off the interior light.. You can get them new from Ford,, It is a 2 minute fix but in the interim you can either pull the bulb out of the holder or try and move the disc anti-clockwise to turn the interior light off ... Stick the screwdriver under the disc with the tab missing and head into Ford with it and ask for a newie..
Old 28-02-2006, 03:59 AM   #8
XR6-VCT-2000
Fantastic Plastic
lol , or yes if u dont actually have 1 then its as the above as racecraft mentioned ..
Old 28-02-2006, 04:13 AM   #9
Mechan1k
Mechan1k's Avatar
The little knob next to the right side of the steering wheel
Old 28-02-2006, 04:19 AM   #10
Jimmeh
You legends, thanks for the fast replies.
You guys were right about that cluster dim switch.... I didnt know it doubled as the interior light switch! :
Very much appreciated.
Regards,
Jimmeh
Old 28-02-2006, 04:20 AM   #11
XR6-VCT-2000
Fantastic Plastic
lol , thats kewl , took me a while to find it when i first purchased my car too , as i didn't get a handbook with the car ..lol , good to hear its not a problem anyway ;)
