Blood, sweat & tears
Hi Guys
I want to get the best performance cam I can get.. probably from crow cams.. but keeping stock ecu and no Chip Do i just need the camshaft or other parts with it? It's for an EA Ghia Also ..(I should probably post a new thread but i'll ask here anyway) I've seen a lot of photo's of EA, EB, ED Engine bays where the owners have made a bit of a shield near the airbox to keep engine heat away.. kind of a cold air induction system I guess.. does anyone know how to make one of these or if you can buy them? My loan just got approved (It's only a small loan!) and once my cars painted I want to get Extractors, 2.5 exhaust and high flow cat, and the cam..Then I'll be happy ![]() cheers for any help :voldar02:
2001 AUII SR 5 Speed ![]() Liquid Silver Inside:Momo Gear Knob Schmick Pioneer Headunit w/ Dolphinvision ![]() 4 Channel Kicker Amp to decent speakers; Alpine Monoblock to Pioneer Subwoofer; Tuned to perfect clarity- Outside: Pure Sexy Falcon w/18" BA XR8 Factory Option Mags Clear Side Indicators Coming soon: Pedders lowered Sports Ryders all 'round Extractors/Exhaust/Hi-Flo Cat |
Yep you can pick up a cam shaft and shim from Crowcams and not have to worry about the ecu.. While your at it I suggest getting a Vernier adjustable gear, makes life easier to time it, and you can 'trick' the computer..
as for the head shields ive seen them for sale at Repco.. IF you dont have the airbox and your running a pod, its actually illegal if you dont have some kind of shield.. |
#3 | |||
I think I'd have to get a pro to install it and do the timing.. what do you think i'd be looking at for labour here?
Adapt or perish...
Stiddy, with Crow Cams, you don't need shims with them.
I have a Crow cam in my machine, I also got the valve springs replaced and have a vernier gear installed too. I don't have a chip yet, it seems to be running A1 at the moment, I'm expecting the chip to fix the doughieness down low though. Two pointers though, make absolutely sure you have the right parts for your car, and choose your mechanic wisely. The second part I did right, I was originally going to take it to a mech who "forgot" that Ford I6's were OHC.
Carless
Did you get the springs from crow or just get the mechanic to change them, how much is the chip going to cost you?
#6 | |||
Son of Wolverine
Turbo's are great, but I'd rather be blown |
http://www.crowcams.com.au/templates...A-AU-OHC.shtml
Looking at that site. I'd want the 2222549 Cam and XR6 Valve springs? (7739-12) would this fit my EA?? what about the vernier adjustable gear?? I have no clue with all this stuff except the cam I just want to know what to order so i can go to my mechanic :P
REMEMBER THE FOLLOWING POINTS.
(1) New lifters should always be fitted with a new camshafts ahh what?
http://www.crowcams.com.au/templates...ierGears.shtml
uhhh i found the adjustable vernier gear.. looks expensive.. do you think i'd need a new timing chain.. car does have 280 000k's :P
#10 | |||
Adapt or perish...
I got the double valve springs from Crow, and ordered the gear from Crow via Repco. Make sure you get the right retainers for you car too. Otherwise the collets won't fit, and you'll be in trouble then. Chip I already have, going to cost $550 installed and tuned.
Carless
You wouldn't mind making me a parts list with crow order numbers would you? so I don't stuff up!
I just want to be able to place the order and know i got everything right. Do you think the chip is really needed? I suppose i can always upgrade later How much the actual chip
#12 | |||
#13 | |||
Adapt or perish...
Parts list I got for my car. Cam - 2222549 Double Valve Springs - 7333-12 Retainers (AU) - Can't remember Vernier Gear - CS6EA V
Carless
#14 | |||
Thanks heaps mate ![]() ![]()
#15 | ||
Adapt or perish...
Just make sure you get retainers for an EA... not an AU.
Carless
#16 | ||
but everything else you listed is fine for my order? doing all this stuff to my EA will probably make it about the same power as a stock AU lol
#17 | ||
Adapt or perish...
Yeah, no problem there.
Carless
