#61 | ||
That would be great except i have NO operating system at all...
#62 | ||
True Blue
A problem I discovered today is that when I upgraded to Windows 10 my "Kaspersky Internet Security" was non-compatible and was not working at all. I only realized this as I hadn't seen an update for a day or two and discovered it wasn't running at all and I couldn't get it to start either. After a bit of online research I managed to get back.
For those with the same problem all you have to do is uninstall it (but keep your license when asked) and go to the Kaspersky website and download the latest version of the virus software you have. I don't know if this is the same for other programs but thought I would share in case any other punters are in the same boat!! |
#63 | |||
#64 | ||
I am Batman
Boot into safe mode then shut it down. Should work after a reboot then. If not boot into recover and hit the repair option.
Rebuilt Boss260 with #Kellogs 1500hp forged and balanced crank#Manley forged flattop pistons with a 9.5/1cr#4340 forged h-beam rods with arp bolts#Clevit performance rod and main bearings#full ARP headstud kit#total seal rings#Mantic twin plate development clutch and lightened flywheel#Mellings uprated oil pump#Mainforce Performance Supercharger kit#AU motorsport 345mm big brake kit. Now sat on an engine stand going nowhere
#65 | ||
Earnin' and Burnin'
It still has internet explorer installed, when you start edge, one of the options you can pick from within edge is open in internet explorer and it will pop up, no need to install anything
Sent from my Nexus 5 using Tapatalk
![]() ![]() SO FAR Genie Headers, 100cell Cat, 3" SS exhaust, Nizpro Valve springs, Powerbond Under Drive, Pod filter, 3 inch intake, big mouth intake, Iridium Spark plugs, Atomic VIPER manifold. TO BE INSTALLED Raptor V 14psi, Frozen Boost W2A, 3,7's & LSD, Auto Rebuilt GOAL: 270+rwkws My BA MKII Raptor Supercharged build |
#66 | ||
If you open explorer 11 go to the help button, and then internet explorer help, you will find a button that says make internet explorer 11 my default browser, then you can enable the tool bars that seem to have disappeared from Edge
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
