Old 18-10-2006, 08:30 AM   #1
GK
Walking with God
GK's Avatar
Default Coolant Leak
Hi all,
Looking at some earlier pics of Casper's car, I noticed what appears to be the AU coolant drip / stain. It's in this first pic, the red stain on the flat shiny alloy of the aircon compressor (It is the aircon compressor right?)
The circle (red) is the stain, the green circle is the thermo housing and hose and the yellow circle is ? I'm not sure what this house and metal housing is called, but I suspect that this is where the coolant leaks from.
My S2 SR doesn't leak here at all, but my S1 Futura sure does. On my car the stain is green of course, as I use green coolant.
What have others found? How do you fix it? What's the cost of fixing it?
Cheers,
GK
P.S Hope Casper doesn't mind me using the pic of his car?
Now gone!
On LPG
Want a Full Life? John 10:10
Old 18-10-2006, 09:33 AM   #2
Mechan1k
Mechan1k's Avatar
Probably the thermostat housing seal is leaking .... or it could be coming from the hose that goes back to the header tank ... the first thing to do is replace the seal ... but seeing as the thermostat is cheap .... may as well get a new thermostat and seal ... not sure if there is a seperate gasket as well.
Especially seeing as it is getting into warmer weather too.
There was a thread with prices for parts for replacing a thermostat and seal .... all up it's be about $30 in parts from memory. Maybe not even that.
Mechan1k is online now   Reply With Quote Multi-Quote with this Post
Old 18-10-2006, 10:11 AM   #3
GK
Walking with God
GK's Avatar
Have had that thermostac seal replaced, still leaking.
I don't actually think that was what was leaking. It's the hose underneath.
Any ideas people?
GK
Now gone!
On LPG
Old 18-10-2006, 12:00 PM   #4
EvilChief
Boost Addict
common problem for falcons to leak there. its either the seal between head and thermostat housing (thermostat housing sometimes warps due to heat and leaks anyway), or it leaks from the big or small hose on the thermostat housing due to corrosion.
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2006, 04:56 PM   #5
Autocade
GK
I have found that if the hose clip is positioned too far away from the flange of the pipe housing that under pressure it can push past the gap and cause small leaks
Try loosening the hose clip (when cold)& slide it along the hose
Get it as close to the flange (will look like a bump under the hose)as possible then re-tighten
Be careful not to put it on top of the flange just right next to it
Autocade
Autocade is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2006, 05:45 PM   #6
skap
Its the by-pass pipe o'ring
Take the thermostat out, replace the seal, and also replace the thermostat by-pass pipe o'ring. When you take the old one out you will see its all squared.
There are 2 10mm bolts holding the by-pass pipe on the thermostat housing one is underneath the inlet manifold & one is on the thermostat housing.
Anthony
skap is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2006, 06:05 PM   #7
Racecraft
they call me Tibbo
Racecraft's Avatar
Anthony
Yep it is the o-ring on the steel pipe that goes from the lower thermostat housing around the engine and to the back of the water puump.. and feeds the heater tap iirc
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2006, 07:23 PM   #8
GK
Walking with God
GK's Avatar
Cheers all,
GK
Now gone!
On LPG
Old 18-10-2006, 11:03 PM   #9
wesomc
wesomc's Avatar
Have seen some bypass outlets on the upper housing leak through the sealant (between the alloy and the outlet).
If you can't get the upper to lower housing to seal, try some ultra blue on the new thermostat seal then refit the upper housing
wesomc is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2014, 06:05 PM   #10
vince
Default Re: Coolant Leak
Hi,
I have a leaking thermostat housing. I have replaced the thermostat and o-ring, but it is still leaking. Does anyone know of a sealant to use on the o-ring?
Thanks
vince is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2014, 08:06 PM   #11
Ford Falcon XR6
Ford Falcon XR6's Avatar
Massive thread mine !!!
But I had the same issue with my Au i6 turned our to be the upper half of the thermostat housing was warped due to being over tightened replaced it then it never leaked a drop
Ford Falcon XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2014, 02:07 PM   #12
mik
mik's Avatar
I usually wack a bit of gasget silastic in the thermostat housing regardless of the o ring, I use whatever silastic gasket stuff I have laying about , but I prefer the red orange stuff , I think its called copper silastic if I can get my hands on it.
Old 20-10-2014, 06:40 PM   #13
GasoLane
Former BTIKD
GasoLane's Avatar
Sounds like the stuff I used to use, comes in a tin with a brush, called Cat Red from a Caterpillar dealer?
Old 20-10-2014, 06:52 PM   #14
mik
mik's Avatar
I cant remember the exact name(getting bad in my old age), it comes in a copper colored tube, it seems not bad stuff (sticks like poo to a blanket) .
Old 20-10-2014, 09:27 PM   #15
sikford
THE Fairmont Ghia 75th
sikford's Avatar
Recently replaced all the hoses on the au as well as the water pump and did the thermostat pulleys tensioner belt etc etc...
Did all these things and after I was done now I have a leak from the bottom pipe on the thermostat housing which is quite annoying. Is it the same as the back of the water pump pipe with just an o-ring? When I replace the o-ring do I need to seal it with anything else?
Current Ride : AUII Fairmont Ghia : 75th Anniversary Limited Edition
Current Mods-HD Built Gearbox+(Mirror Polished, Modified Valve Body), 2500rpm Hi-Stall Convertor(TCE Custom Built), BIG Trans Cooler, Braided Lines/Speedflow Fittings, 2.5" Exhaust, Custom CAI, Detailed UnderCarriage, Custom SQ Stereo Install.
My Ride
My Build Thread
sikford is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2014, 12:14 AM   #16
Spurious
The heater hose under the thermostat housing is prone to leaking under pressure. My AU2 often left tell tale marks on the A/C compressor.
I did major head off surgery recently & used high temp silicone on the Heater pipe connection & thermo' housing. & vwhalla...no leaks!
Your water pump rear hose fitting could do with silicone too I'd say. Just don't fill the system up with coolant straight away after applying sealant, give it a chance to dry first.
Also my thermostat housing radiator pipe fitting was a little course to the touch so I attacked it with some wet/dry sand paper. It still weeped a little so a ran a bead of silicone just on the end of the hose & it stopped.... & yes the hose clamp was super tight & I used new hoses too!
Spurious is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2014, 07:33 PM   #17
vince
Thanks everyone,
I ended up just buying a new thermostat housing and seal, wasn't too expensive.
Ford also told me that some do warp and all you can do is buy a new one. So I thought I would just replace it and now the problem is fixed.
