08-09-2014, 05:55 PM | #1501 | ||||
FG GT 5.4 w/ additions!
I did find however, I gained about 2-3Kph ave speed on my regular rides just with the tyre change from 23 to 25.
08-09-2014, 06:36 PM | #1502 | ||
Ford screwed the Falcon
Get to the carpark, drop the bike and flake out on the ground.
Falcon: 1960 - 2016 My cars Current ride 2016 FG X XR6 - 6 speed manual Previous rides 2009 FG XR6 - 6 speed auto 2006 BF MkII XT ESP - 6 speed auto 2003 BA XT V8 - 5 speed manual 1999 AU Forte - 5 speed manual 1997 EL Fairmont - 4 speed auto 1990 EAII Fairmont Ghia - 4 speed auto |
4 users like this post: |
08-09-2014, 06:48 PM | #1503 | |||
Critical Thinker
Haha. That's a fair call. Just wondered if you had some form of plan to avoid feeling sore a few days after.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
08-09-2014, 07:00 PM | #1504 | ||||
Many pros are now running 25mm tyres for that exact reason. EDIT: More info here http://www.competitivecyclist.com/learn/25-vs-23
08-09-2014, 07:20 PM | #1505 | ||
Critical Thinker
wow, thats something I didnt know. Cheers for the heads up.
08-09-2014, 10:53 PM | #1506 | ||
Ich bin ein auslander
Rubino Pro slicks in 23.
Growing old is compulsory, growing up is optional! |
08-09-2014, 11:06 PM | #1507 | |||
Interesting, when I started road racing we all rode 27x1 on your high end race bike and 27x1 1/8 on your training bike. Yes I have been in this sport long enough to remember imperial sizes. The idea was to go narrow and hard on race wheels. Then came the metrics and the practice was the same but even more so as the metrics came narrower than the imperials did and I remember running 23 on my training wheels, 21 on my road race wheels and 19 (@160-180 psi) on my TT bike. The ride quality on a tubular (singles) in a 19 at 160 psi was awful, you might as well be riding concrete wheels but that same sensation made you think it was fast. Now it seems we were wrong all that time.
08-09-2014, 11:29 PM | #1508 | ||
Anyone know what pressure I should be running in my mountain bike tyres? Maximum on the sidewall? They seem to bulge a bit with me on it, I'm not sure what the bike shop set them too.
Or maybe I'm just too fat and this problem will go away if I use the bike more Where can I get a tyre inflator where I can see what pressure I'm putting into them? Is there an adaptor that fits into a car tyre inflator? |
08-09-2014, 11:36 PM | #1509 | |||
Yes you can get adaptors for the valves.
08-09-2014, 11:51 PM | #1510 | ||||
I have now started back riding for fitness and fun in the last couple of years. As with most things I get into, I read up and absorb as much info as possible. Out of curiosity I decided to give the 25s try, and have not looked back. Obviously there is a point where it becomes too wide though. I have even heard of some pros running 28mm tyres in classics like Paris - Roubaix and Tour of Flanders. clearly this is due to the lower pressure factor = softer ride, but the trade off cant be too bad or they would "suffer" through with the 23 or 25 tyres..
09-09-2014, 12:11 AM | #1511 | |||
http://www.norco.com/bikes/mountain/...er/charger-91/ Local dirt back roads mostly. |
09-09-2014, 08:25 AM | #1512 | |||
Rob
http://www.rei.com/product/657109/to...ort-floor-pump that is what i have, but there are a range of brands out there and prices start from about $40 depending on quality. they are readily available at all decent bike shops and sporting goods shops. |
09-09-2014, 09:25 AM | #1513 | ||||
I would assume you are just running standard tyre and tube and not tubeless. If so 35-40 psi will be ok. You can go up and down from there depending on where you ride and what you like. Go harder pressures if you have some weight on you or your are riding a lot of hard pack/pavement. The down side of high pressures is you lose some of the tyre deformation and therefore there tyre contact patch that gives you grip. Also high tyre pressures will bounce off ruts and rocks etc which will lose grip rather than absorbing them. Go too soft and you will run the risk of pinch flats. I am 90+ kgs at the moment and I run 35 psi on my MTB with no problems.
09-09-2014, 12:13 PM | #1514 | ||
Critical Thinker
Anybody used these tires before and can give an honest review?
http://www.wiggle.com.au/schwalbe-ul...ing-road-tyre/ http://www.wiggle.com.au/veloflex-co...ing-road-tyre/
09-09-2014, 12:39 PM | #1515 | ||
I haven't used them, but I have used other Ultremo's, they seem fine.
My personal favourites are Michellin Pro Race 4 - Endurance and Vittoria Rubino Pro's.
flickr |
09-09-2014, 12:43 PM | #1516 | ||
Critical Thinker
What are they (Ultremo's) like in terms of puncture resistance?
09-09-2014, 02:54 PM | #1517 | ||
As I said, I didn't use the ones you quoted, but the ones I used were fine really.
Like anything, if you hit a big enough piece of glass or metal, it doesn't matter what you're running. I once used the Schwalbe durano's, meant to be the best commuting tyre on God's green earth. No joke, first ride I got a puncture. But that was caused by a large nail that I didn't see due to the rain, so didn't matter what I had on, it was going to get punctured. The Michelin Pro Race 4 Endurances have done really well for me. They've gone through quite a bit of smashed up glass and held up beautifully *touch wood*
flickr |
09-09-2014, 05:17 PM | #1518 | ||
Critical Thinker
Cool. Cheers for the heads up.
10-09-2014, 05:43 PM | #1519 | ||
Hi All,
long time lurker, I have recently dusted off the mountain bike and getting back into cycling after a very long hiatus, and just joined the strava group. I am hoping to buy my first road bike later in the year so will probably bug you all with lots of questions cheers Dale
Current Ride 2012 Mitsubishi Triton Dual Cab ute : |
10-09-2014, 05:51 PM | #1520 | ||
Critical Thinker
Welcome Dale. Good to hear you getting back on the saddle. Let us know if anyone here can assist.
10-09-2014, 06:25 PM | #1521 | ||
Rob
10-09-2014, 07:04 PM | #1522 | ||
Thanks guys
12-09-2014, 10:19 PM | #1523 | ||
2 solid rides on the new bar tape, 106 km yesterday with 2 major climbs and another 53 km today with no major climbs but as I live in a semi rural area all my rides are done on pretty rough roads.
Just to re-cap I have fitted Specialized gel pads and Specialized Roubaix wide tape. There is a hell of a lot more padding and it really does take some of the vibration out of it. I have noticed that it gives a strange sensation when climbing out of the saddle as the gel allows a lot of movement under your hands and it feels like something is really flexing on the bike. It feels great in the drops, seems to smooth out some of the curves of my Ritchey WCS anatomical bars and allows great grip in the 80km/h plus descents, really happy with this. So it seems worthwhile if you have to endure pretty rough roads but I think it would be overkill if you spend most of your time on smooth roads. In that case I think the Roubaix wide tape without the additional pads would be a good choice.
13-09-2014, 08:14 PM | #1524 | |||
2017 Mustang GT (Magnetic) |
13-09-2014, 09:23 PM | #1525 | ||
I have been using for some years Vredestein Tricomp tyres 23' on my race bike , and have been alternating between Schwalbe ULtremo ZX 23' or Continental 4000 Grand Prix 23' on my trainer and commuter.. I must say the Schwalbe feel the nicest in all weather conditions , and you get very good k's out of them , but the Vredestein matched to the Zipp 404 , just feel faster - but not has forgiving ...
13-09-2014, 11:12 PM | #1526 | ||
13-09-2014, 11:26 PM | #1527 | ||
Rob
too small for me.
if anyone comes across a half decent roadie in large (somewhere in the mid to high 50's cm) in the brisbane area, then let me know. haven't ruled out buying a 2nd bike to keep at my folks place up there so i have something to use whilst on holidays. |
18-09-2014, 08:17 PM | #1528 | ||
Adam.
Rode through a Booze Bus last night & got breath tested, lol. Anyone else had this before?
2004 BA XR8, Winter White, Manual, 20's, Bluepower Custom Tune, Difilippo Extractors, etc - 241.4rwkw Build Thread SOLD 2007 BF Mk2 Winter White E-Gas Wagon, 6 Seater. 2002 AU3 XR6, Liquid Silver, Manual, Sunroof, LPG, Rebel Kit, BA GTP's, Momo Steering Wheel & Gear Knob. |
18-09-2014, 08:30 PM | #1529 | ||
Critical Thinker
Not me. But since we ride what is considered a legal vehicle on the roads, we need to make sure we abide by the same rules in terms of alcohol limits.
18-09-2014, 08:53 PM | #1530 | ||
Adam.
Defiantly, I wasn't fussed by it at all.
