Prev Previous Post   Next Post Next
Old 15-03-2014, 07:05 PM   #2
vdo
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Consistently offers competent electrical and technical advice regarding Ford electrics, especially instrument clusters. He's retired but offers his services for repairs for next to nothing.
Default Re: Help needed sourcing pinto engine parts
While the head's off, I would get the valves checked and reseated. Any engine reconditioner will give it a good going over and replace any faulty or worn valves, valve seals, springs and valve seats including your bent one and they'll replace the spring at the same time. Worth doing.
If you just buy a new valve and install it, the odds are that it won't be seated properly, it needs to be re-seated and if you're a novice, it's best left to the pros.
They'll probably also deck the head surface and you can fit a fresh head gasket... all good and probably better acceleration too.
Of course, you can usually specify how much or how little you want to get done, depending on your budget.
vdo is offline   Reply With Quote Multi-Quote with this Post
