Old 07-12-2013, 11:09 PM   #1
jt-1994
Default Strange engine noise
Hey guys have a strange issue with my car. When the car is idleling on flat level ground the engine makes no abnormal noises but when it's idling on an uphill incline It makes a soft knocking sound irregularly. Ive just changed the oil today so there is plenty of oil in the engine and the oil pressure is also correct any one have a similar experience before?
jt-1994 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2013, 12:38 PM   #2
mif73
CNC fixer guy
mif73's Avatar
Default Re: Strange engine noise
Does it happen when idling only facing up or down or both ways?
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2013, 08:03 PM   #3
jt-1994
its only happens while facing uphill
Old 09-12-2013, 11:09 PM   #4
mif73
CNC fixer guy
mif73's Avatar
Is it a 6?
Have you popped the hood to try and isolate the noise? (Hold a long screw driver up to your ear and the other end on various parts of the engine).
Could also be power steer pump or trans fluid low?
Old 10-12-2013, 07:41 PM   #5
jt-1994
yes its a 6 and a manual no I havnt tried that yet as I just assumed it was the engine but the noise most audable from under the car rather than the top in the engine bay
Old 10-12-2013, 07:56 PM   #6
mif73
CNC fixer guy
mif73's Avatar
What if you put your foot on the clutch slightly? Does it change or go away?
Old 13-12-2013, 07:24 PM   #7
jt-1994
nah it doesn't change at all even when clutch is fully engaged so I'm assuming that rules out the transmission side of things
Old 15-12-2013, 10:54 AM   #8
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
Oil level too high, uphill the excess oil runs to rear of sump and crankshaft slaps the oil as it rotates.
XC50077 is offline   Reply With Quote Multi-Quote with this Post
