Old 12-08-2013, 01:43 PM   #1
thebecbec
thebecbec's Avatar
Default Where to get WEBER carby's tuned in VIC?
Hey guys,
I have a set of twin 45 weber carbys on my mark 2, and I am having a really tough time trying to find someone in vic to tune them! Every carby person I speak to doesn't want to touch them.
They are in desperate need of a tune up, so any advice would be fantastic.
Cheers,
Bec
thebecbec is offline   Reply With Quote Multi-Quote with this Post
Old 13-08-2013, 08:50 PM   #2
muzzy
muzzy's Avatar
Default Re: Where to get WEBER carby's tuned in VIC?
Is it tuning or setting up? If its just tuning, a digital tacho, digtial vacuum meter and little Internet research and do it your self, if its setting up, then you will need to find a performance shop with dyno and an old fart(like me) working there.
RS2000 5 speed
Twin 44idf webers + other goodies
muzzy is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2013, 08:55 AM   #3
thebecbec
thebecbec's Avatar
It's just a tune at this stage, but I have a feeling that something might be wrong with them so I may need some expertise. I will do some research tonight and see what I come up with
Old 14-08-2013, 07:17 PM   #4
muzzy
muzzy's Avatar
PM me I might be able to help
RS2000 5 speed
Old 21-08-2013, 05:48 PM   #5
Puzzlescort
Rally Nut
Puzzlescort's Avatar
if you still want to have them tuned / dynoed then there are a few places around
try MAMMI Motors
they are way down south but well worth the drive......they run cars with twins themselves
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2013, 04:21 AM   #6
Daniel B
Daniel B's Avatar
Hey mate, where abouts in Melb are you? There's a few guys around that will do them, and they don't have to be done on a dyno if the person knows what they are doing they can get them pretty close, although it is recommended to get them spot on.
Daniel B is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2013, 07:54 AM   #7
muzzy
muzzy's Avatar
If they don't need to be set up on a dyno, how do you adjust wot AF ratio?
I rest my case, guess doesn't work!
RS2000 5 speed
Old 22-08-2013, 06:59 PM   #8
Daniel B
Daniel B's Avatar
You use a portable AF ratio meter in the exhaust. Not ideal but will make sure to keep it safe. And as i said before, it's good if the person knows what they are doing.
Old 23-08-2013, 08:30 PM   #9
TER2BO
REV8380
TER2BO's Avatar
You could try Ian Tate (Ex Harry Fifth/Peter Brock) Tate engines etc.
He has been doing 45 mm twin Webbers for lots of the Historic racing cars i.e GT and Lotus Cortinas and many others and has a dyno and has jets etc.
He moved to 31a Metropolitan Ave Blackburn from Hawthorn several years ago.Ph. (03) 9877-2317
TER2BO is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2013, 03:32 PM   #10
tickford2001
Try Warren Heath Performance, he tunes Webers regularly and is well known for his small ford builds and tuning. He also stocks a full range of jets and other parts as well. Best to phone Warren directly on 0409 934 058
tickford2001 is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2013, 07:54 AM   #11
Puzzlescort
Rally Nut
Second vote for Warren as well
