12-08-2013, 01:41 PM | #1 | ||
Gents . . .
I've recently noticed that the cam tensioner adjuster is leaking oil in my AUII 6 (non VCT), so have decided to fix it at home. I have a couple of questions: 1/ Which is the best brand of drive belt, and where 2/ Which are the best idler pullies to buy, I've seen them at around $23 in Super Cheap, but am suspicious of their quality. 3/ Simply removing and replacing the cam tensioner, to seal it from oil leaks, will that have any unintended affect on the actual tension applied to the cam? Thanks Last edited by 4ford; 12-08-2013 at 01:42 PM. Reason: Overlooked mentioning the engine size! |
13-08-2013, 10:11 AM | #2 | ||
Au Falcon = Mr Reliable
G'day 4ford,
1) Gates are pretty good brand of drive belt 2) go a metal instead of a plastic pulley but have not seen a plastic pulley disintergrate either. 3) have a look at this thread with some great how to's, http://fordforums.com.au/showthread.php?t=11336109 cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) |
13-08-2013, 08:58 PM | #3 | ||
Next upgraded Mk1 Leopard
I forgot about this one
UK
