Hi there guys,
just put new bearing hubs on my AU1 wagon, Does anyone know how tight i should tighten the big nut? Many thanks. |
Got Ghia?
Believe it is the same as au2... somewhere near 300nm will do it.
(manual gives the 305nm figure, also references a range of 260-350nm)
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold ![]() 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
Ft.....
#4 | |||
If you don't have a torque wrench that will measure up to the above figure, you can count the number of threads the nut on your other wheels is on from the end of the shaft. Then apply that number to the wheel you want to tighten. It should be close to factory spec. |
