Old 04-02-2013, 09:24 AM   #1
peterljohnson55
peterljohnson55's Avatar
Default Renew head lining ... $?
What is a reasonable price to have the head lining redone?
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2013, 09:30 AM   #2
KR1STO
Just another mock-up..
KR1STO's Avatar
Default Re: Renew head lining ... $?
From people I've spoken to, it's anywhere between $120-$200.
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2013, 10:35 AM   #3
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
G'day Pete, if you can remove it & prep it it'll be alot cheaper to get done - just make sure whoever does the job gets the same factory fabric if you want the same stock look again. i was quoted $220 for the full job, i removed & prepped the lining & it cost me $120. Obviously ring around your local area for a good price.
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2013, 11:34 AM   #4
peterljohnson55
Thanks Kr1sto and Maka.
Maka, I had thought of doing the prep but concerned about how to transport to trimmer's shop. Spose I will have to put it back in place for the trip.
Old 04-02-2013, 12:21 PM   #5
Maka
Maka's Avatar
Good point Pete, best to use a ute/wagon to transport the lining to the motor trimmers if you prep it - you might be lucky & find a mobile trimmer that will come to your residence to do the job. The biggest hassle i found was getting the lining in & out of the car, definately a two man job if you dont want to bend / crease anything. Good luck with it mate!
cheers, Maka
Old 04-02-2013, 01:19 PM   #6
ronwest
All Bran = Regular Member
If they know what they are doing it will only take them an hour or maybe an hour and a half to do the job. Just time to go for a wander and grab a cup of coffee.
You'll have to weigh up whether the $50 or so you save is worth the hassle of removing it, transporting it to and from etc.
Old 06-02-2013, 03:55 PM   #7
Vincenzo
Vincenzo's Avatar
Up here in Darwin where things are usually far more expensive than down south it cost $140, was finished in less than 70 minutes and looks proper schmick.
The guy that did mine said sometimes he has exchange linings as particular models start coming in around the same time - something to consider. You could be in and out in 30 minutes.
Cheers Vincenzo
$DO || ! $DO : try
try: command not found - (YODA the Geek)
"WRC is for boys, Group B was for men" - Juha Kankkunen 4 times World Rally Champion
Romanes Eunt Domus - 'people called Romanes they go the house' - You mean Romani Ite Domum
[SIGPIC][/SIGPIC]
Vincenzo is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2013, 09:11 AM   #8
AU1XLS
AU1XLS's Avatar
Not to mention the clean up because the old foam makes a hell of a mess of a cloth interior
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 09-02-2013, 10:57 AM   #9
Maka
Maka's Avatar
You are supposed to remove the lining from the interior before starting to prep it The $100 i saved was well worth it considering it took less than an hour to prep the lining ect, plus i learnt something new about fettling my AU. Each to there own i suppose!
cheers, Maka
Old 10-02-2013, 01:20 AM   #10
peterljohnson55
I decided to attempt the repair myself, in situ, as nothing to lose. Besides, the car is an old girl and I am not a perfectionist in this situation. It will take a few sessions of doing the following but so far it is working.
I cut some tiny 2mm long slots with a craft razor blade in the lining at different places. Into those slots I inserted a tube extension from the spray nozzle of an aerosol glue can and sprayed the glue around. Then I smoothed it out carefully, not pushing sideways much at all but rather pressing the lining back up against the foam. I held the lining against the backing board with a thin-ish pillow under which I placed egg cartons and held them in place with thin bamboo sticks (from the garden). the sticks were flexible and were pressed against the floor, making sure to provide some vertical pressure to the cartons. Everything was left in place over night and most of the repaired area had held up when examined in the morning.
I'll have to do that two or three more times and it should be fixed good enough.
Old 10-02-2013, 08:49 PM   #11
peterljohnson55
Angry Re: Renew head lining ... $?
NOPE ... that didnt last .... maybe need a stronger glue. ... DANG
Old 10-02-2013, 09:22 PM   #12
BHDOGS
heat probably killed it get some proper glue
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2013, 03:00 AM   #13
peterljohnson55
Agreed, BHDogs, but what type? And it has to be packaged as an aerosol complete with a tube delivery. Open to suggestions.
Old 11-02-2013, 11:40 AM   #14
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Seriously, just pay the $160 or whatever. Believe me, it's worth every cent.
Old 12-02-2013, 12:45 AM   #15
Murph-51
Murph-51's Avatar
add a sunroof and BOOM the price sky rockets!!!
My upholsterer who uses a sunroof specialist quoted myself $490
Murph-51 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2013, 12:50 AM   #16
ronwest
You are more than likely trying to glue the lining to the crumbling old foam. Ain't gonna work.
Try a few thumb tacks.
Old 12-02-2013, 11:08 AM   #17
gra
gra's Avatar
if you are not too worried about the look try a stapler works just as good as tacks but not as obvious 2 seconds and voila done lets face it ur never going to see it and if u do it means ur not looking at the road lol
gra is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2013, 12:59 PM   #18
FGII-XR6
FGII-XR6's Avatar
I can put you on to a bloke in Rutherford who is reasonable. PM me if interested
[SIGPIC][/SIGPIC]
Rides:
Old 12-02-2013, 04:16 PM   #19
_Ben
_Ben's Avatar
While we're here, anyone know any cheapish guys in the Gold Coast area who do it?
_Ben is offline   Reply With Quote Multi-Quote with this Post
