Old 21-01-2013, 04:00 AM   #1
louiethelouper
td-76
Default Eb v8 cortina
Hey guys i got a eb 5 litre sitting around that i need to get rid of and i was thinking can that running gear fit into a td cortina. Has it been done.
louiethelouper is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2013, 02:40 PM   #2
XY Chaser
Default Re: Eb v8 cortina
No reason why not. The windsor motors have been fitted to Cortina's just about since they were new. The only problem you may have is that the emission controls. As the motor is built later than the car, it must comply with the later build, in your case the engine. That's in NSW, not sure of other states. It's a pretty common project for a lot of guys on here.
XY Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2013, 03:07 PM   #3
dieseltrain79
Should just require a carbon canister , the coolant lines run through the TB egr plate , catalytic convertor/s in the exhaust and fuel filler neck changed to suit unleaded only ?
That's all that comes to mind .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
