Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
08-01-2013, 12:28 PM | #1 | ||
Member
Matt, considering that there are issues with fitting the 4 piston Brembo's to the rear of the AU3 utes due to the bearing failures and pad knock off, are there any alternative upgrades available beyond just braided brake lines, rotor and pad upgrade? i.e. is there a twin piston calliper upgrade or anything else available?
Current vehicles: MY12 Land Rover Discovery 4 TDV6, MY03 Land Rover Discovery 2 HSE Td5 off road modified and 1989 Mazda NA MX-5 toy car. Previously: 1992 Ford EBII Fairmont, 1994 Ford EF Falcon XR6 supercharged, 2003 Ford BA Falcon XR6 Turbo 325rwkw, and 2002 Ford AU3 Falcon XR8 Pursuit 250 270rwkw. |
08-01-2013, 01:58 PM | #2 | |||
Race Brakes Sydney
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
08-01-2013, 10:00 PM | #3 | ||
T-Series Club Member Vic
Yep, it fouls. Did on my IRS setup when fitting territory spec 328mm gear anyway. Easy to sort though, but not exactly show quality once bent out of the way and then back over the new calipers. With the IRS setup it's very tight fit between the toe adjuster, the backing plate and the rotor...but doable.
