Old 17-12-2012, 11:21 PM   #1
CONGO MILLENNIUM
Default Changing Fairlane seat belts
G'day all, the drivers side seat belt in the Fairlane needs to be changed due to frayed webbing and not retracting fully.
My question is how to remove the plastic covers on the B pillar?
I presume they would unclip.
CONGO MILLENNIUM is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2012, 11:54 PM   #2
2002au
Define definitive
2002au's Avatar
Default Re: Changing Fairlane seat belts
Yep just pop off easy job to do
BF F6 TYPHOON in NEO #718 ~ 356rwkw :
BF XR6 TURBO in SILHOUETTE
2002au is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2012, 06:30 AM   #3
tim_pato
tim_pato's Avatar
Carefully pry the top of the top trim panel towards the the centre of the car, once the top clips pop lift itup. then at the top of the lower trim panel there is 2 screws undo them and pry the panel out in the same manner as the 1st. you will need the 6 sided torx bit to change the belt, t50 its called???
au2 dedicated lpg tonner, just want a wee bit more stab.
wanted TS/TL50 front seats any condition pm me
tim_pato is offline   Reply With Quote Multi-Quote with this Post
