Hi I am having trouble with the dash in my dads AU3 forte I6 the gauges are all reading wrong no speedo, tacho on 3500 at idle, temp straight to hot etc any info would be great, car is running fine.Thanks Andrew
Flairs - Truckers Delight
have you tried another cluster?
No have not tried cluster, I don't have access to one.Is this a common problem?
had a similar problem ended up being one of the plugs at the back of the cluster wasnt connected properly
