#63 | ||
Solution Was Boost 4?, 6 & 8
Congrats Ivan picked up plenty down low, did someone capture the run on video?
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
#64 | ||
Thanks guys , 60 ft was 1.48, Danny did some fine tuning on the dyno after 1 yr, so added a tad more timing in the mid and top, so Car was how I raced at Heathcote bar the tuning.
The gain seemed to be the track also with more grip as 60 ft dropped from 1.58 to 1.48.
Daily driven workute....10.33 @ 136mph
Gtx3582 Stage 2 Nizpro kit. HEADSEX TUNED Last edited by xr6t_ute; 17-11-2012 at 02:28 PM. |
#65 | |||
Yeh got video of it Mark, timing boards wernt working so didn't know what my times were till I picked up my timeslip.
Gtx3582 Stage 2 Nizpro kit. HEADSEX TUNED |
#66 | ||
Bummer you couldn't borrow some weight wheels, would have dipped you into the 10.3 zone no doubt.
[SIGPIC][/SIGPIC]
#68 | ||
Yeh the steel rims are not light, there's not much more room for improvement unless i start taking some weight out. Also if it were a sedan it would see 10.3 not a problem.
#69 | ||
Congrats mate, real credit to both yourself and Headsex's tuning ability.
How do you find using the E85 everyday, especially cold mornings?
FG XR6 Turbo (Manual) - 301rwkws @ 15psi ---------- Rapid Systems Intercooler & Battery Relocation - ID 1000 Injectors - Process West Surge Tank - Venom 100 Cell Bolt On Cat - XForce 3.5 inch Catback - Plazmaman 4 inch Turboside Intake - Crow HD Valve Springs - Glowshift Gauges (Oil temp, Oil Pressure, Boost, Volt) - Malwood Opt 5 - XR50 Interior - FG2 Limited Ed 19's - Nitto Invo's |
#70 | ||
It's not that bad, about 6-10secs to start, fuel consumption is greater though, if you drive a fair bit it will be costly. I get about 300-350 per tank, freeway will of course be alot better.
#71 | ||
You must have one tough BTR in that ute,allot of people at the drags don't realize how heavy the B and F series are,allot of torque/strength is needed to net a 1.4 when shifting over 4000lbs.
Biggest hat possible goes off to ya bloke! |
#72 | ||
GTX Turbo & KB Blown
1.48 60ft
![]() That is rip your head off stuff off the line! ![]() Congrats on the new PB! Jack
DARTH 2008 FG G6ET
465.6rwkw not a 10 @ 134.81 MPH SNOW WHITE 2004 BA FPV PURSUIT 2.6L Kenne Bell Brembos all round Twin Screw Awesomeness Supported, serviced and tuned by BLUEPOWER RACING DEVELOPMENTS http://www.fordforums.com.au/showthread.php?t=11354744 |
#73 | ||
That's where its won, all in the 60..
[SIGPIC][/SIGPIC]
#74 | ||
Don't I know it Mark!
![]() ![]() I look at the street cars running sub 1.70 60ft cars in awe! It is hauling 4000lbs out of the hole. Amazing really when you think of the stress on the components and the grip required! Jack
DARTH 2008 FG G6ET
#75 | ||
headsexTuned
Actually, we are 1 degree timing less in midrange and top end.
Their was other changes that contributed to the small power increase. Good effort on the 60 foot. It's really a treat seeing it happen. Also, it's a flat 20psi tune, no spiking 25psi coming in. I think we can improve your 60 by just having 100duty on the turbo 100% of the time ![]()
headsexTuned
#76 | ||
http://www.fordforums.com.au/attachm...1&d=1353163105
Heres the timeslip from Friday night at Calder
#77 | ||
Ivan did they allow you more than one 10 sec pass?
[SIGPIC][/SIGPIC]
#78 | ||
Yeh no one mentioned a thing, as timing boards wern't operating, so maybe thats why, i just picked up my timeslip from the young fella in the timing box.
I had 4 runs in total... 1st pass - 10.45 2nd pass - 10.51 3rd pass - 10.44 4th pass - 10.53 Tried for more boost off the line but obviously it wasnt hooking up and had a slower 60ft of 1.52
#79 | |||
[SIGPIC][/SIGPIC]
#80 | ||
Yeh much better than the radials
60 fts were 1.481 1.51 1.480 1.52 Plus Calder was better prepped than when we went to Heathcote as no changes were made other than a tickle on the tune.
#81 | ||
Might look into 50/50 rear shocks if they have another street meet at Calder, hopefully that will help a bit more, hopefully the std tailshaft will keep holding on.
#82 | ||
Do you think you can improve on a 1.48 - 60 foot?
[SIGPIC][/SIGPIC]
#83 | ||
I like to believe so... 15pounds off the line was ideal, whereas it slipped off the mark when I tried for 18 pounds, still 1.51 and 1.52 60's, so maybe get the rear to push down harder and not come back up as quick.
I can only try and see I guess, won't know till I try.
#85 | ||
Are the tires turning on the rim at all?
#86 | ||
Yeh i always creep slowly till i hit the second stage light.
#87 | ||
Good question, i didnt even check, i checked it when i ran at Heathcote and it did move about 2 inches on the left side and not even a inch on the right.
#88 | ||
#89 | ||
well im racing against the clock...i want every little poofteenth..hahaha
#90 | ||
What size is the Stall Converter?
[SIGPIC][/SIGPIC]
