Old 07-07-2012, 09:54 PM   #1
muzzy
muzzy's Avatar
Default IDF weber carbs
Has anyone out there have the Ford Rs 2000 44 IDF weber set up, I'm after some information on jet sizes
thanks
RS2000 5 speed
Twin 44idf webers + other goodies
muzzy is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2012, 02:54 PM   #2
JimStone
Default Re: IDF weber carbs
Running ex Fiat 40IDF 14/15 with
34 chokes,
F7 emulsion tubes,
140 mains,
180 airs
62.5 idles,
50 bleeds.
Engine spec is equiv 'stage 2' Vizard spec head, shade under 10.5:1 static compression with Crow 26874 billet cam (dynamic 7.8:1), H&H Electronic dizzy set 36 deg advance at 3500rpm, Pacemaker big bore extractors and 2 1/4 single box exhaust.
Will soon be fitting Piper 285 cam and bump static compression (dynamic up to 8.3:1); will see how that goes but may go to 36 chokes and rejet to suit if the 'wall' comes in too soon. 40s will ultimately limit my full power figures, but I am looking at driveability over bragging rights.
From memory, the factory settings for the 44IDF 40/41s were
34 Chokes
F19 emulsion tubes
145 mains
180 airs
55 Idle
50 bleed
JimStone is offline   Reply With Quote Multi-Quote with this Post
