Old 26-10-2005, 10:22 PM   #1
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
Question Escorts
Has Any one owned or still owning an escort. i have never driven one but i have only heard good things about them. dose any one know how much they weigh for an 1980 ish. not sour witch one to get as i am thinking of turbo charging one. or drop a new SR20DET Motor into it. any faults to look for when bying one or types to look for.
thanx Tom
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-10-2005, 10:40 PM   #2
RSgerry
Well hello Mr Fancypants
RSgerry's Avatar
i am completely biased, but i think they are excellent little cars. i have had a couple and currently own a 1980 RS2000. i havent done an engine swap or turbocharged one so i cant help there. body wise, rust is something to look out for. they rust in the C Pillar. you can check this by opening the boot and sticking your hand up the inside of the pillar. they also rust in the firewall. easy to check again. check under the front carpets for water or rusted out floor. other than that, rust in the usual places for an old car. mechanical checks are the same as other cars. your best bet is to go something with a solid body. bodywork is expensive to get done, but oily bits for Escorts are all over the place and relatively cheap.
two doors are more popular than 4 doors. the RS series are starting to get hard to find. they do show up on ebay etc but can be tatty. good ones are not cheap. i think they weight about 850 kilos or so, so they are not heavy. they dont need a ton of power to make them quick, and the handling is sensational.
good luck.
RSgerry is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 11:43 AM   #3
The MaDDeSTMaN
No longer driving a Ford.
The MaDDeSTMaN's Avatar
Kerb weights:
Mk2 Escort
L 2 door 2L - 955kg
L 2 door 1.6L - 925kg
GL 4 door 2L - 978kg
GL 4 door 1.6L - 948kg
GHIA 2L - 1003kg
VAN 2L - 938kg
VAN 1.6L- 908kg
Auto trans adds 4.5kg
1976 rs2000 - 919.5kg
Not sure about the RS2000, but it wouldn't be much different to the above I'd guess.
I'd personally get something basic, like a L or GL if you're going to do an engine swap, an auto 1600 L isn't worth much, even if it's in excellent condition, and the auto has the bigger trans tunnel for putting in a more modern transmission. Although if you could get your hands ona good Ghia, that way you'll get the better instrument cluster.
One of the worst places for rust is the heater dome, as well as all the spots RSgerry mentioned.
And yes, as was said about, you don't need much power to get them moving, and the handling is absolutely sensational!
Get one, you won't regret it I'm sure! I know I'll be getting another one sooner or later
Originally Posted by russellw
For those who get their jollies attacking other people let me remind you that we will not tolerate this here. If you want to do that then I am sure your presence would be welcomed elsewhere.
The MaDDeSTMaN is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 11:54 AM   #4
jcxr
Tribal Elder
jcxr's Avatar
Ive never owned one but rented a few !!!!!!!!!!!!!!!!!!!
jcxr is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 11:56 AM   #5
brenx
brenx's Avatar
I've had three. A 2*2.0lt 2 doors and a 2.0lt 2 door RS2000. I found them to be very reliable but I'm talking when they were 10yo not 20yo+. A bit weak in the gearbox and diff. Rust in the firewalls a big issue.
If they are still as good as I remember? Definately a fun car.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 12:27 PM   #6
XPcoupe
The Grand Prix
XPcoupe's Avatar
Yep had a yellow RS2000 2 door, I should not have sold it. Excellent car. easy to work on. one day I will buy one again.
Trouble putting a new motor in, is the new motors are design for Front wheel drive, so you will have a bit of fun turning everything around.
Bright Green XP Coupe
9" 3.55 LSD, C10 and mild 302 Windsor
Cruizing the roads 70's style
XPcoupe is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 12:53 PM   #7
Dezza
Parts bin special
Dezza's Avatar
My nanna used to have a MkII Ghia 2.0 2 door, and it was in perfect condition. It rarely got driven, and therefore had low milage (I forget how much it had done). The only thing I didn't like about it was that the speedo was in MPH. Pity it got sold about 5 years ago. There wasn't a scratch on it. This car got me interested in Escorts, particularily the MkII.
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 01:14 PM   #8
Craig
RIP Craig - 13/11/08
Craig's Avatar
LOL, thought the same thing when i saw the Heading.................... : : :
Craig is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 01:48 PM   #9
big_pete
Sublime
big_pete's Avatar
my first car was a MK2 escort.
loved it. such a fun car. i wish i still had it
sounded wicked with a 2inch exhaust and extractors!!!
big_pete is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 01:52 PM   #10
GRNKPR
DPC PERFORMANCE Race prep
GRNKPR's Avatar
The two door or four dorr and do they charge extra for a grease and oil change : : : : : : :
: : i will excell with the knowledge i get on here : :
FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria
Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club
GRNKPR is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2005, 02:28 PM   #11
zetec
Zoom Zoom
zetec's Avatar
Nothing like a Mk II with a heavily worked 2.0L Zetec twin cam.... mmmm twin throttle bodies.... mmmmmmm Escort.
2012 Mazda3 MPS
Old 27-10-2005, 02:44 PM   #12
The MaDDeSTMaN
They sure do sound good with extractors and an exhaust, even stock they sound suprisingly good.
Some videos from my old 2L Mk II Escort before I sold it, make sure your speakers are turned up and the volume is turned up ;)
Playing with the go pedal with it parked and not in gear, watching the tacho
0 to 60km/h, just letting the clutch out gently at about 1000rpm
I miss that car, can't wait to get another 2L Escort...
Old 27-10-2005, 02:56 PM   #13
jcxr
Tribal Elder
jcxr's Avatar
grnkpr, u going to epping show on cupday
Old 27-10-2005, 10:15 PM   #14
4.0i_SiX
SiX_iN_a_RoW
4.0i_SiX's Avatar
I miss my lil escort
such a fun car and they handle like theyre on rails
Oh yeah, my G6ET eats diff bushes for breakfast!
4.0i_SiX is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2005, 02:34 PM   #15
blitzmile
check out my thread on 'escort engine choice.' theres a bit of talk about sr20's and a couple of pics of an esky with an sr20det in it.
blitzmile is offline   Reply With Quote Multi-Quote with this Post
