#1 | |||
Hi guys, just purchased a Focus to use as the every day driver and as the shopping trolley, needed to stop driving the Sprint so much.
Any way have a couple of issues. Firstly I noticed went I drove it for the first time at night the dash lights were really dim, I noticed a rotating switch next to the headlight switch but this doesnt make any difference, any thoughts?? Also I noticed the bonnet near the windscreen seems to 'flap' about a bit, is this normal - the bonnets on these do seem a bit flimsy compared to the old E-series. Other than that, I loving it so far, the 1.8 seems to run on the smell of an oily rag, the seats are comfortable, the factory stereo seems pretty reasonable and the boot is HUGE! Cheers Richard
FM Mustang GT, manual - Daily driven Live, Love, RACE SOLD: AU III XR8 Quote:
welcome to the focus family, I came from an e-series to a focus aswell. one of the first thing I noticed aswell was that the focus has a supprisingly big boot. I know with my mums LR the dial near the steering wheel adjusts the headlight hight, used when towing so your lights dont blind on comming cars when you have extra weight on the back.
Id say the owners manual should tell you for sure if thats what its for. As for the bonnet, I'd check to see that the bolts are tight on the bonnet hinge. |
Old enough to know better
Welcome to the Focus.
A couple of hints. There are TWO dials near the light switch. One goes up and down. That's the headlight level adjustment, so as Neale says, be careful you don't tilt them up in drivers eyes. The second one is below that and moves from side to side. That's the one that adjusts the brightness of the instrument lights. To the right for the brightest setting Bonnet wobble. Believe it or not, that's standard. Mine has always done the same thing. I've tightened the bonnet hinge bolts and it makes no difference. But I've done over 100,000 km in mine now and it has never caused an issue. Enjoy! No doubt other queries will pop up so don't be shy in asking. (ps I assume you've worked out how to open the bonnet? Keyhole behind badge?)
Motorsport Guru
Quote: "Bonnet wobble, believe it or not that's standard".
Ah, well I must be lucky as mine's rock solid but one other problem (as it's been mentioned plenty before) watch out for the panel between the windscreen and bonnet that has the Pollen Filter. If it's not replaced correctly it'll allow water in to the footwell/s. It's happened to my '03 and the panel has been replaced and it's starting to warp AGAIN for the second time.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System. Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle. Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust. Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus. |
#5 | ||||
#6 | ||||||
