10-04-2011, 02:58 PM | #1 | ||
Shockwave
Can anyone tell me if it's possible to fit a series III or II factory 6 stacker into a series I?
Have done a couple of searches, but cant see an answer. Currently have a daggy head unit in it and want to put a stacker in instead. Can get a series III, but will it fit straight in? Thanx, |
10-04-2011, 05:33 PM | #2 | ||
I think it will fit straight in but your steering wheel controls will not work
10-04-2011, 06:02 PM | #3 | ||
Shockwave
So the steering wheel controls will only work with a series I stacker (in my series I AU)?
Might have to look for the correct unit them. Thanx, |
10-04-2011, 07:52 PM | #4 | ||
Pretty sure the Series 2 and 3 units are longer/sit deeper in the dash.
10-04-2011, 07:56 PM | #5 | ||
Series II or III will not fit into AU without some hacking; but it can be done if you are determined (and patient).
10-04-2011, 07:56 PM | #6 | ||
Shockwave
OK Thanx Smoo & T3man.
I guess that seals it then, have to find a correct series I. Cheers, Last edited by BlueBear; 10-04-2011 at 08:09 PM. Reason: opps |
10-04-2011, 09:37 PM | #7 | ||
IF you have a series one cluster in a series 2 the volume goes up to full as soon as you turn it on smoething to do with the steering wheel controls and the speed alert. so I assume you will get the same problem if you put a S2 stacker in a S1
[SIGPIC][/SIGPIC]
