Old 02-03-2011, 08:24 PM   #1
adrian k
adrian
adrian k's Avatar
Default XR8 rear brakes
I have noticed that my rear rotors are dull, on closer inspection it doesnt look like the pads are marking the rotors at all. Now I upgraded to Tickford premium brakes recently, but the red rears were definatly bitting on the TS (where i took them from), but this was going on evern before i swapped the calipers so its not a caliper issue imo.
I put new pad in on the weekend and went to bed them in, with heavy braking, i only got slight marking on the rotors. the pistons do move in and out with the pedal, so no problem there.
just wonder if anyone else has noticed this or had this problem?
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2011, 12:59 AM   #2
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
I've noticed that previously with surface rust or when i painted the rotors, that it does take a very long time for it to come off (AU1 ute with AU2 fronts).
A BA/BF master cylinder would get the rears working more, as they are more balance in volume between front to rear.
I don't think my solution of installing adjustable brake bias is the easier/every day option
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 03-03-2011, 06:26 AM   #3
adrian k
adrian
adrian k's Avatar
i might stick my finger on the rears after a few stops to see if its hot or not. in the TS at track days i got the rears alsmost blue so they do get a work out, but the XR8 just doesn't seem to using them much. the car stops on a dime though so would be surprised if rears are completely idle. but that is a good suggestion about the BA master cylinder. could stuffed seals in the master cyclinder plunger casue a bypass and hence not enough rear pressure?
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
